![]() | | #121 | ![]() |
| can't take out voltron ![]() Join Date: Apr 2012 Location: Wood-Ridge, NJ
Rep Power: 4910 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,141
![]() | | #122 | ![]() |
![]() | | #123 | ![]() |
![]() Join Date: Nov 2010 Location: Dover, DE
Rep Power: 164 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 271
This is great! Thank you for this!
__________________ 2012 CWP MS3 w/ Tech Package Cobb AP (Clean-up since tuned by Jon) | Corksport SRI + TIP | UR TBE | CX-Racing FMIC | Autotechs | TS DP BOV | JBR Stage 2 SSP + Knob | JBR 88 duro RMM | Corksport Mudflaps | RX8 wheels | Eibach pro kit | NGK step colder To be installed: Qualir mzd723 |
| The Following User Says Thank You to MizzyMS3 For This Useful Post: | ms3blackmica (09-19-2012) |
![]() | | #124 | ![]() |
(Thread Starter) | Not Ranked : 0 score Not a problem. If you have any other questions, feel free to ask. |
![]() | | #125 | ![]() |
![]() Join Date: Oct 2011 Location: Murrieta, CA
Rep Power: 1882 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,262
Groaned at 22 Times in 17 Posts
If this was covered before, I apologize. I am looking for a consensus. 1. What is the target # and what is an acceptable #. (for example, anything less than .08 etc. with 0 being ideal.) Also, is there a oh crap moment? (If it is above 10.0 do a maf cal right now kind of thing) 2. Is a + or - number prefered if there are LTFT values. 3. Do you believe revisions are necessary? If so at what interval. 4. If someone is doing a cal, starting with + numbers, next revision they are -, and the third revision they are back in the +, what is the best course of action? Thanks a bunch in advance. This is a great tool! |
![]() | | #126 | ![]() |
2. They can be + or - (absolute value). The ECU will either be pulling fuel out (-) or adding fuel in (+). As long as your within + or - 3%, you have a good maf calibration. 3. What exactly do you mean? It usually takes a couple revisions until your MAF cal is nice and tight. If you add any intake flow mods, you will have to revise. 4. This can happen a lot. For example, someone might have a 4.7% LTFT. Then they take 4.7% out, and now they have a LTFT of -3.9%. And then they try to add 3.9% and the same thing happens. This is usually the cause of not putting enough miles on the car before taking a maf cal log. Also some people like to only add as much as they need..For example, if your LTFT is +4.7%, some people might add only 4% to the maf breakpoint in order to bring the LTFT's around 0.7%. That is another way of going about it. Takes some time and practice. Also make sure you have no leaks. | |
| The Following User Says Thank You to ms3blackmica For This Useful Post: | UnknownSuperhero (09-19-2012) |
![]() | | #127 | ![]() |
| Eth Fiend ![]() Join Date: May 2010 Location: Murhpysboro, Illinois
Rep Power: 6798 ![]() Thanks: 10,664
Negative is probably preferred for the closed to open loop transition range. The thinking is the car will be biased rich as it transitions, thus being safer. It doesn't exactly work this way, but whatev, it's a good sentiment haha. Revisions are usually only necessary when hard parts change. I tend to leave them as is so I can identify significant variances caused by other issues. Again, 1 proper Cal is typically all it takes. [If you dick with vtcs or repair issues, this may not be true]. If you're doing a MAF Cal right, you won't have revisions with significant variance after. If you see big swings, you're likely trying to tune around a leak.
__________________ -06 MS6 - Tuning the high compression forged mill -Corn fed 07 MS3 - Sold | |
| The Following 3 Users Say Thank You to phate For This Useful Post: |
![]() | | #128 | ![]() |
(Thread Starter) | Not Ranked : 0 score UPDATE: I cleaned up the original post as it was a bit messy. It is much cleaner now. I also editied the original post with instructions and an example on how to scale your MAF curve for a larger sized intake, as it seems many people are upgrading and want to know how to adjust their MAF curve for this. Cheers EDIT: Raider, Can you update the OP of this thread that was placed in the KB section? I wanted to edit it myself but i do not have access to do so. All you have to update is the text at the beginning of the OP with the text you see in this thread. Thanks
__________________ 2009 MS3 GT: Stock HID's and an NJSPEED3 Mani ![]() ![]() "NJ Nator the home of makeshitfit technology" - voltron "I didn't build it hoping for your approval...I built it because it meets mine." Last edited by ms3blackmica; 10-07-2012 at 11:01 PM. |
| The Following User Says Thank You to ms3blackmica For This Useful Post: | 802MS3 (10-04-2012) |
![]() | | #129 | ![]() |
| Scammer Hunter ![]() ![]() Join Date: Mar 2008 Location: Jacksonville, FL
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,858
Groans: 449
done
__________________ ![]() ![]() ![]() 1) Looking to Buy a used Mazdaspeed? Read this! 2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here. 3) Wanna buy and sell here? DONATE for VIP 4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting! 5) Help MSF grow with FAQ threads!? |
| The Following User Says Thank You to Raider For This Useful Post: | ms3blackmica (10-11-2012) |
![]() | | #130 | ![]() |
![]() Join Date: Dec 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
![]() | | #131 | ![]() |
yes you need to perform a OL-WOT MAF Calibration if you are not hitting targets provided you have no leaks. | |
![]() | | #132 | ![]() |
When I accelerate my car really burn Rich and black smoke comes out when I check the spark plug they are really really black
![]() | | #133 | ![]() |
I hope you know that black smoke out of a DISI is pretty normal | |
![]() | | #134 | ![]() |
I have an aem afr and it goes to 17 to 18 then it stops to read 3 dots and red light
![]() | | #135 | ![]() |
you need to fix your car. judging by the other posts you have made in other threads, you say you have a gt40 turbo? did you install a larger intake and not scale the maf ? | |
![]() | | #136 | ![]() |
I don't even self know how to scale it? I order a cobb it should be here 2marrow Last edited by Island mazda; 12-18-2012 at 04:53 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #137 | ![]() |
![]() Join Date: May 2010 Location: Benton, AR
Rep Power: 205 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 119
| Not Ranked : 0 score Crap dude, stop where you are at and sell your car....or put it back to stock. I'm no expert but I'm not sure you are ready for any mods. LOL.
__________________ 2010 Mazdaspeed 3 Liquid Silver Metallic HTP 3.5" Full Intake | HTP Battery Tray | CP-E TMIC | Corksport Recirculation and Boost Tubes | Corksport Oil Catch Can | Corksport TMM insert | Greddy Type S BPV | eBay Test Pipe | Cobb Shift Weight | JBR Solid Shift Bushings | JBR TIG's | JBR EGR Delete | SU RMM | Autotech HPFP internals | Cobb AP | ITV22's Stratified tune in progress. |
| The Following User Says Thank You to jdmage_mx5 For This Useful Post: | bstover17 (12-19-2012) |
![]() | | #138 | ![]() |
![]() | | #139 | ![]() |
| Banned ![]() Join Date: Aug 2011 Location: Springfield/Union NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,560
| The Following User Says Thank You to dantes5823 For This Useful Post: | ms3blackmica (12-18-2012) |
![]() | | #140 | ![]() |
stop driving car until you get AP | |
![]() | | #141 | ![]() |
| The Following User Says NO Thank You to Island mazda For This Un-useful Post: | Raider (12-19-2012) |
![]() | | #142 | ![]() |
![]() Join Date: Nov 2011 Location: Naperville, IL
Rep Power: 2090 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 350
Groaned at 46 Times in 31 Posts
| Not Ranked : 0 score Raider; please kill it with fire! Stop posting, stop driving your car, stop touching your car, and for the love of god please read the damn forum before you blow your car up! Tapatalk LIKE A BOSS!
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, HTP full 3" intake system, HKS SSQV 4 full VTA, Corksport 65mm Racepipe, Cobb AP, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 70duro PMM, JBR cylindrical shift knob, DDM tuning HID's lows and fogs, Resonator Delete. |
| The Following 2 Users Say Thank You to GODspeed7 For This Useful Post: | CamSpeed360 (12-19-2012), ms3blackmica (12-19-2012) |
![]() | | #143 | ![]() |
![]() | | #144 | ![]() |
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, HTP full 3" intake system, HKS SSQV 4 full VTA, Corksport 65mm Racepipe, Cobb AP, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 70duro PMM, JBR cylindrical shift knob, DDM tuning HID's lows and fogs, Resonator Delete. | |
| The Following 3 Users Say Thank You to GODspeed7 For This Useful Post: |
![]() | | #145 | ![]() |
Groans: 449
| Not Ranked : 0 score I am going to groan you. I" do not care who you are, where you are from. You were sent a welcome PM with important links. We have a knowledgebase, with a "start here". That was answered in there. Please go to the KB and read up.
| The Following User Says Thank You to Raider For This Useful Post: | ms3blackmica (12-19-2012) |
![]() | | #146 | ![]() |
(Thread Starter) | Not Ranked : 0 score you need to help yourself first
| The Following User Says Thank You to ms3blackmica For This Useful Post: | dantes5823 (12-19-2012) |
![]() | | #147 | ![]() |
![]() Join Date: Aug 2012
Rep Power: 0 ![]() Thanks: 0
This is a great tutorial but I'm a real noob when it comes to tuning. I really want to get my maf calibration done but I just know I will screw it up. If I send you my logs could you fix them up for me? I would be willing to paypal you some money for your time.
![]() | | #148 | ![]() |
| bigger on the inside ![]() Join Date: Feb 2011 Location: Wichita Falls, TX
Rep Power: 157 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26,890
MAF cal is easy, but if you're concerned, go here for help.
__________________ 2009 CWP MS3 GT Rally Armor Flaps | Gen Pu Wheels | JBR RMM/RSB/v2 SSP/Spherical Knob/TIGs/Boost & Bypass Tubes TWM Full Replacement Shifter | CS SRI/TIP | Koni FSD 4045 | Matt Damon OCC | Cobb DP/AP | CP-e TMIC/HPFP PTP VVT Actuator/Injector Seals & Studs | ARP Head Studs | Samco Rad Hoses | Redline Leather Shift & E-Brake Boot BNR S3 | Stratified Boost Dial/Tune in progress On the shelf: CP-e Gauge Pod, SPC Camber Arms and a bunch of minor suspension stuff |
| The Following User Says Thank You to magicka For This Useful Post: | ms3blackmica (01-21-2013) |
![]() | | #149 | ![]() |
![]() Join Date: Nov 2010 Location: Stormville, NY
Rep Power: 569 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,359
Groans: 138
Thanks!
| The Following User Says Thank You to Tommy For This Useful Post: | ms3blackmica (02-05-2013) |
![]() | | #150 | ![]() |
Rep Power: 17 ![]() Thanks: 0
Hello, I recently received my Cobb AP, and decided to download the SURE stage 1 OTS map off of the cobb website. I am currently only running a SURE Aeros V2, and SideWinder TIH. After watching your very well done videos, I have been attempting to achieve a MAF calibration with some confusion. Once I completed the log just as you do in your video and look at my data, I am seeing something quite different under my LTFT column. My LTFT are showing 7.03 throughout the duration of the log until hitting 80 g/s when the LTFT turns to 0. Any idea what I am doing wrong? I only have about 80 miles on this map, is that enough for a log? Thank you so much for any assistance you may be able to offer. Thanks again, |
![]() | | #151 | ![]() |
![]() | | #152 | ![]() |
Hello, Thanks again for your help, I really appreciate it. Here is another log I just took including a few more types of data. If anything else is needed I will gladly do another log today. |
![]() | | #153 | ![]() |
![]() Join Date: Jun 2008 Location: Tucson, AZ
Rep Power: 73 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 59
I may be wrong, it's kind of hard to read that on my phone. But it appears you are hitting your breakpoints and the ltfts are changing as they should. just tap it in |
![]() | | #154 | ![]() |
Rep Power: 0 ![]() Thanks: 1
Hey guys. I just received my AP, so I'm trying to learn a bit here. I have a 2012 MS3 and just installed my GFB BoV and CS Stage II SRI and I want to flash the OTS Stage1+CS+TIH 93 tune and start putting on the miles for the mafcal. I have already adjusted the breakpoints as OP suggested and before I get started had a few questions... 1. Even though I selected an OTS tune designed for my intake i assume I will still need to scale the MAF curve, is this correct? 2. If it is correct I am using the formula provided and coming up with (x^2)/(s^2) where s^2 is equal to the stock MAF Diameter Squared s^2 = 66.5^2 = 4422.25 Corksport SRI = x x = 67.82 x^2 = 4599.55 so... 4599.55 / 4422.25 = 1.04 and then ill multiply all the cells in the MAF table using the 1.04? Does that seem right? 3. Do I do that adjustment prior to getting some miles on the ECU? 4. I'm holding AFR's between 11.4 and 11.6 with the BoV Venting 100% is it recommended to stop that now? I have heard both positive and negative things about this. Thanks in advance, I'd rather get it right the first time and thank you OP for the great videos and guides it is really appreciated |
![]() | | #155 | ![]() |
![]() Join Date: May 2011 Location: Port Orchard, WA
Rep Power: 87 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 282
Hey, I used this tutorial awhile ago but just wanted to stop in and say thanks for your work putting this together!
![]() | | #156 | ![]() |
![]() Join Date: Jan 2012 Location: Pensacola, FL
Rep Power: 150 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 71
| Not Ranked : 0 score If you have an OTS for that intake, the you don't need to scale. That will cause all sorts of issues. Perform the MAF cal as documented and be happy. You will never get it perfect, so don't stress over the last 2% or so. As far as running 100% vta... I wouldn't, unless you pick up a Guardian Angel. You are going to run rich at shift and likely leak under vacuum. This will eventually lead to carbon build up around the O2 sensor and a $300+ part to replace. tapawhat
__________________ Corksport Downpipe /w Highflow Cat | Corksport Catback Exhaust HTP 3" MAF and Turbo Inlet in Candy Blue over Chrome Smoke Beachshoer Intake Manifold P/P /w VTCS Delete Sure Shortcut | Sure Anchors | Sure 1/8 TIG Cobb AP | Cobb FMIC | Cobb Sport Springs Stratified Automotive Guardian Angel Go Fast Bits Respons (100% VTA) Autotech Internals Stratified Tuned ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following User Says Thank You to aldekei For This Useful Post: | Linus2600 (04-06-2013) |
![]() | | #157 | ![]() |
Thanks for the input, just flashed it so now its time to start getting some miles on the car. I guess ill set the BoV back to 50/50 or rull recirc. The GA looks cool but internals are next so that little luxary will have to wait. I appreciate the input man, logs to come.
![]() | | #158 | ![]() |
![]() Join Date: Nov 2010 Location: 93401
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 361
Groaned at 4 Times in 2 Posts
Sent from my Incredible 2 using Tapatalk 2
__________________ Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP Stage 2 tune - Koni yellow struts - H&R springs _ (Looking for BT) | |
![]() | | #159 | ![]() |
Ok so did my first MAF Cal and must have fucked up the math somewhere, 30 miles later i threw a p0300(random misfire) and reverted bak to the OTS map with my ltft from +10/-8. Logged about 80 miles yesterday, redid the calibration and after first attempt im at -2.3/+1.8 consistanly...Gonna drive another 75 miles or so and re log. One more question, if my ltft is sitting at 0.0 on my AP when im on the throttle (about 30 miles in) thats good right? Im assuming that means my ecu does not feel that it has to do any adjustments, is that correct? Thank you again for the time |
![]() | | #160 | ![]() |
That really depends on what you mean by "on the throttle". If WOT, then you will always see 0, this is where the second half of calibration comes in. As to the code: That can be caused by a number of things. Did you feel a stutter or loss of power? Did the code come on under partial throttle while cruising? As I recall, that code can be triggered by an imbalanced clutch as well, so it is really tough to troubleshoot. Google it, and try to run down what others have found. Worst case, stock out and take the car into a dealership. tapawhat
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Coats |
| MAF Calibration | gfather | Mazdaspeed3/6 General Discussion | 8 | 05-24-2012 08:09 PM |
| KR after MAF Calibration | ms6mil | MazdaSpeed 3/6 - ECU Computer Tuning | 2 | 05-11-2012 10:20 PM |
| MAF calibration | Xploder08 | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 04-25-2012 04:00 AM |
