-   MazdaSpeed 3/6 - ECU Computer Tuning (http://www.mazdaspeedforums.org/forum/f9/)
-   -   Maybe a stupid question..... (http://www.mazdaspeedforums.org/forum/f9/maybe-stupid-question-108795/)
twintzs 03-24-2012 05:01 AM
I am following Abilor's rooming guide by noobies. How does having a manual boost controller affect the waste gate duty tables or any other tables for that matter?
I am running a mazdaspeed cai, forge recirc, sure tip, auto tech internals, CPE high flow catted down pipe, turbosmart in cabin mbc, and hks cbe.
I also changed some of the ots figures that were more aggressive than the figures in the guide. Should I have left the aggressive figures alone?
Thanks in advance
twintzs 03-24-2012 05:03 AM
I forgot to add that I have the mbc set at 19 psi. It tapers down to about 16.5 to 17 psi.
jack_hammer 03-24-2012 05:41 AM
Hi, i installed a part on my car that, if used improperly, could explode my engine. At any rate, how does it work?
Thanks guys!
Sent from my LG-MS690 using Tapatalk
trf5000 03-24-2012 05:57 AM
Dude you seriously need to dump that boost controller. The stock system is adequate for the stock turbo with light bolt-ons. Your gonna fuck up your shit.
twintzs 03-24-2012 07:32 AM
Problem was using the ots maps it was supposed to hit 19 but didn't get past 16.
leon78 03-24-2012 08:07 AM
Strong fail in this one.
chuckms6 03-24-2012 11:52 AM
9 times out of 10 the stock turbo will not be able to hold boost after 5500 rpm. Secondly, remove the mbc and use the stock ebc. It is more than capable, safer, and easier to implement.
tapatalkin to you
twintzs 03-24-2012 03:39 PM
Damn I guess the mbc will be coming out.
superdave2335 03-24-2012 03:50 PM
the stock ebc holds boost steady compared to an mbc. i ditched mine. if your tuned with an ap or equivalent your boost will be at what ever you tune is set at. mine holds steady at about 16 and dosent flinched throughout the whole rpm range
twintzs 03-25-2012 06:29 AM
Can anyone tell me what exactly is "E-Tuning"?
StayBroke 03-25-2012 06:34 AM
it wheres where a tuner sends you revision's threw email.
anavrinIV 03-25-2012 06:46 AM
Just an FYI on this since it wasn't covered exactly...
The MBC will override the boost control tables in ATR since the ECU isn't connected to the boost controller anymore. You could put the WGDC tables to basically whatever because they don't do anything at that point.
But as everyone else said, the EBCS is the way to go with this car, at least on stock and bolt-on turbo setups because you can control everything through the ECU
zpele 03-25-2012 08:10 AM
Methinks there is a troll attack going on.
Either that or people drank retard juice and stupid popcorn for breakfast.
twintzs 03-25-2012 11:06 AM
What do you say that? Not sure if you are referring to me?
TexasSpeed3 03-25-2012 11:57 AM
at least this one donated
Page generated in 0.17673 seconds with 11 queries
