Like Tree2Likes
  • 1 Post By jack_hammer
  • 1 Post By twintzs
 Old 03-24-2012, 06:01 AM   #1
twintzs's Avatar
Posts: 40   (View Stats)
twintzs has a spectacular aura abouttwintzs has a spectacular aura about
Default Maybe a stupid question.....
I am following Abilor's rooming guide by noobies. How does having a manual boost controller affect the waste gate duty tables or any other tables for that matter?
I am running a mazdaspeed cai, forge recirc, sure tip, auto tech internals, CPE high flow catted down pipe, turbosmart in cabin mbc, and hks cbe.
I also changed some of the ots figures that were more aggressive than the figures in the guide. Should I have left the aggressive figures alone?
Thanks in advance
twintzs is offline   Reply With Quote
The Following User Says NO Thank You to twintzs For This Un-useful Post:
jack_hammer (03-24-2012)
 Old 03-24-2012, 06:03 AM   #2
twintzs's Avatar
I forgot to add that I have the mbc set at 19 psi. It tapers down to about 16.5 to 17 psi.
 Old 03-24-2012, 06:41 AM   #3
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
Hi, i installed a part on my car that, if used improperly, could explode my engine. At any rate, how does it work?
Thanks guys!
Sent from my LG-MS690 using Tapatalk
superdave2335 likes this.
it's fun to do bad things
The Following 4 Users Say Thank You to jack_hammer For This Useful Post:
Don06speed6 (03-24-2012), TexasSpeed3 (03-25-2012), trf5000 (03-24-2012), zpele (03-25-2012)
 Old 03-24-2012, 06:57 AM   #4
trf5000's Avatar
Posts: 2,290   (View Stats)
Dude you seriously need to dump that boost controller. The stock system is adequate for the stock turbo with light bolt-ons. Your gonna fuck up your shit.
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
 Old 03-24-2012, 08:32 AM   #5
twintzs's Avatar
Problem was using the ots maps it was supposed to hit 19 but didn't get past 16.
The Following 2 Users Say NO Thank You to twintzs For This Un-useful Post:
TexasSpeed3 (03-25-2012), zpele (03-25-2012)
 Old 03-24-2012, 09:07 AM   #6
leon78's Avatar
Posts: 2,595   (View Stats)
Strong fail in this one.
2013 Scion FR-S (Whiteout)
Less parking more racing
leon78 is offline   Reply With Quote
 Old 03-24-2012, 12:52 PM   #7
chuckms6's Avatar
Posts: 1,618   (View Stats)
9 times out of 10 the stock turbo will not be able to hold boost after 5500 rpm. Secondly, remove the mbc and use the stock ebc. It is more than capable, safer, and easier to implement.
tapatalkin to you
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
 Old 03-24-2012, 04:39 PM   #8
twintzs's Avatar
Damn I guess the mbc will be coming out.
 Old 03-24-2012, 04:50 PM   #9
superdave2335's Avatar
Posts: 924   (View Stats)
Groaned at 9 Times in 6 Posts
the stock ebc holds boost steady compared to an mbc. i ditched mine. if your tuned with an ap or equivalent your boost will be at what ever you tune is set at. mine holds steady at about 16 and dosent flinched throughout the whole rpm range
 Old 03-25-2012, 07:29 AM   #10
twintzs's Avatar
Can anyone tell me what exactly is "E-Tuning"?
 Old 03-25-2012, 07:34 AM   #11
StayBroke's Avatar
Posts: 2,075   (View Stats)
it wheres where a tuner sends you revision's threw email.
 Old 03-25-2012, 07:46 AM   #12
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Just an FYI on this since it wasn't covered exactly...
The MBC will override the boost control tables in ATR since the ECU isn't connected to the boost controller anymore. You could put the WGDC tables to basically whatever because they don't do anything at that point.
But as everyone else said, the EBCS is the way to go with this car, at least on stock and bolt-on turbo setups because you can control everything through the ECU
Blue Pu.
 Old 03-25-2012, 09:10 AM   #13
zpele's Avatar
Posts: 1,654   (View Stats)
zpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the world
Groans: 354
Groaned at 213 Times in 109 Posts
Methinks there is a troll attack going on.
Either that or people drank retard juice and stupid popcorn for breakfast.
2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now)
2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy
zpele is offline   Reply With Quote
The Following 2 Users Say Thank You to zpele For This Useful Post:
leon78 (03-25-2012), TexasSpeed3 (03-25-2012)
 Old 03-25-2012, 12:06 PM   #14
twintzs's Avatar
What do you say that? Not sure if you are referring to me?
 Old 03-25-2012, 12:57 PM   #15
TexasSpeed3's Avatar
Posts: 1,996   (View Stats)
TexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the world
Groans: 273
at least this one donated
2011 Black Mica - Daily
JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp
TexasSpeed3 is offline   Reply With Quote
Stupid thread, stupid question but will ask anyway JohnMS3 MazdaSpeed 3 - Engine, Transmission & Driveline 1 01-26-2011 12:51 AM
Uhh... Stupid Question ClutchEngaged Mazdaspeed3/6 General Discussion 36 01-16-2011 10:18 PM
Stupid, stupid question........... PureDrive 2010 MS3 - Wheels & Tires 4 12-25-2009 09:27 AM
stupid AP question gtlaw
Cobb Access Port/Maps
4 10-24-2008 10:50 AM
Stupid question TheDoc MazdaSpeed 3/6 - Appearance 2 09-11-2008 05:25 PM
Page generated in 0.34667 seconds with 29 queries
