Like Tree2Likes
  • 1 Post By Haltech
  • 1 Post By Haltech
 Old 03-20-2008, 05:49 PM   #1
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Default Mazda OBD-II Trouble Codes
See attached for detailed codes...
djkemistry likes this.
The Following 5 Users Say Thank You to Haltech For This Useful Post:
Dash08 (08-30-2008), FreeFlyFreak (07-11-2008), SLS MS3 (03-21-2008), wyosaint (05-23-2009), yager (08-06-2008)
 Old 03-20-2008, 05:49 PM   #2
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
jcolton (10-13-2015)
 Old 03-22-2008, 11:28 AM   #3
Performance Racing's Avatar
Posts: 193   (View Stats)
Performance Racing is just really nicePerformance Racing is just really nicePerformance Racing is just really nicePerformance Racing is just really nice
Think you can stick this in the Speed6 section as well? Show some love!
Performance Racing is offline   Reply With Quote
 Old 03-22-2008, 11:35 AM   #4
NYpest's Avatar
Posts: 1,889   (View Stats)
NYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the world
I copyed it over to the the ms6 ECU section.
NYpest is offline   Reply With Quote
The Following User Says Thank You to NYpest For This Useful Post:
occschemguy (03-22-2008)
 Old 01-30-2010, 10:45 PM   #5
mpc12347's Avatar
Posts: 13   (View Stats)
mpc12347 is an unknown quantity at this point
Groaned at 4 Times in 2 Posts
thx
mpc12347 is offline   Reply With Quote
 Old 07-13-2012, 01:44 PM   #6
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
having trouble opening
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 07-14-2018, 05:35 PM   #7
burban861's Avatar
Posts: 1   (View Stats)
burban861 is an unknown quantity at this point
hello my name is Bill I live in Utah and just bought a 08 mazda speed 3
burban861 is offline   Reply With Quote
 Old 06-16-2019, 08:55 PM   #8
AMarquez17's Avatar
Posts: 2   (View Stats)
AMarquez17 is an unknown quantity at this point
Default Noobs first post
Thank you for the add onto the forum, will help me out a lot in the future. I have a blacked out 2008 gen 1 ms3, still a noob I’ve had it for 3 months but I’ve been in the Mazda wave for a while. Here to learn and grow.
AMarquez17 is offline   Reply With Quote
 Old 06-16-2019, 09:01 PM   #9
AMarquez17's Avatar
So if my car is running rich on idle bank one would I have change my o2 sensors, fuel system flush, ecu tune, get a Cobb, or what else would be another form to turn off my cel (check engine light)
 Old 06-18-2019, 04:12 PM   #10
MSMS3's Avatar
Posts: 2,691   (View Stats)
Groans: 150
This thread is to let people know what the codes are - it is not really intended to serve as a diagnosis for individual problems. It would be best for you to identify your specific CEL code number and then research that code number. You are not likely to get many responses by posting in this thread.
To do a search simply use Google. Begin your search with the term "mazdaspeedforums" (remove quotation marks) followed by your CEL code number.
Then read the threads that correspond to that code. Chances are high that there will be multiple threads that will help you diagnose and solve the problem.
If not, then start a new thread based on the results of your search and remaining unresolved issue.
The Following 3 Users Say Thank You to MSMS3 For This Useful Post:
Db09ms3 (06-18-2019), Jeff23spl (06-19-2019), Vansquish (06-18-2019)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f9/mazda-obd-ii-trouble-codes-281/
MazdaSpeed 3 - ECU Computer Tuning [Archive] - Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-30-2008 09:03 PM
Turboxs FMIC trouble. Davidb MazdaSpeed 3/6 - Turbo Induction 4 04-03-2008 09:03 AM
Link to trouble codes...... winniep MazdaSpeed 3/6 - ECU Computer Tuning 2 03-20-2008 06:22 PM
Page generated in 0.30311 seconds with 28 queries
