-   MazdaSpeed 3/6 - ECU Computer Tuning (http://www.mazdaspeedforums.org/forum/f9/)
-   -   Monitoring w/ AP (http://www.mazdaspeedforums.org/forum/f9/monitoring-w-cobb-access-port-62582/)
86AmishMs3 08-04-2010 05:19 AM
Originally Posted by wankular (Post 599415)
What gas stations do you guys go to? I try to hit a Shell and stay far away from Circle K's.
chevron, there's a shell station right by me, but it seems that their 91 is like 89.
AZSPEED3 08-04-2010 10:05 AM
SO last night I went over all my hoses for leaks. Everything seemed ok, I did notice that my hot side and cold side pipes the clamps were a little loose. So I tighted everything up super tight. Hopefully that is what the leak was. I didn't get a chance to datalog again last night. It was still around 105 degrees at 9pm. I can't wait for the summer to get over and start really enjoying my car again.
Qtip 08-04-2010 10:17 AM
The issue can also be the by-pass valve, are you running the stock one? Maybe it's leaking.
AZSPEED3 08-04-2010 10:42 AM
I had the Greddy BOV on for a while but have taken off and replaced with stock when I flashed the 1.07 map on. I even put a gasket on with the stock BPV to help prevent any leaking. Also I made sure to check my lines on the BPV and tighten everything back down.
At this point not sure what could be causing such high wastegate duty.
I will get another datalog tonight and see if this helped any.
evidence 08-04-2010 12:53 PM
Build a boost leak tester for a few bucks. Easiest way to confirm.
AZSPEED3 08-04-2010 02:33 PM
I've been wanting to build one but I believe you need an air compressor for it and I do not have one. If there are other ways of doing it can you link me in the right direction.
thanks
evidence 08-04-2010 05:15 PM
thanks
I'm not sure of any other way to pressurize the system outside of a compressor. Harbor Freight has smaller ones on the cheap though that will do the job. Handy to have to fill your own tires, instead of spending a buck at the gas station. Also at some point you'll be ready for air tools.
1/4 HP, 3 Gallon, 100 PSI Oil Free Compressor
1/3 HP, 3 Gallon, 100 PSI Oilless Air Compressor
Page generated in 0.17803 seconds with 11 queries
