![]() | | #1 | ![]() |
![]() Join Date: Dec 2010 Location: Virginia Beach
Rep Power: 83 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
Groaned at 9 Times in 6 Posts
(Thread Starter) | Not Ranked : 0 score datalog8.csv datalog9.csv
__________________ 2008.5 cwp ms3 |
![]() Join Date: Aug 2011
Rep Power: 24 ![]() ![]() ![]() Thanks: 0
This is something that mazda implemented to save the drive line and mounts. Post shift, boost is cut for a second or two before ramping up again, SUPER ANOYING! Cobb has managed to get around this and implemented a fix in the latest revision of OTS maps over the last year or so. Or you can search post shift stutter fix to fix it yourself in ATR for older version maps.
__________________ 2006 MazdaSpeed6: Cobb SF intake, AP Stage 1+SF 91oct. Vokl Gram light 57 optimize wheels. KO4 replaced by dealer Aug 2011 (no more smoke screen!). |
Ok, i looked through tha thread that lex made for stutter during 2-3 gear shifts and thats exactly whats happening. I have some pretty sticky tires, and making decent power so i guess my load is high when i shift. The only thing i see to adjust is the ign. timing limit from -3 to 0, but i doubt that will have much affect. Has anyone found a solution for this? Lex rfinkle2
| The Following User Says Thank You to paulwalll For This Useful Post: | ABSpeed3 (08-09-2012) |
![]() | | #4 | ![]() |
Rep Power: 11895 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42,819
Groans: 235
You can try the fixes in the thread below (hyperlinked to posts concerning shift folders) SWAS - DISCONNECT ON A GEN2
![]() | | #5 | ![]() |
| Able ![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 3262 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,137
Groans: 124
__________________ ![]() | |
| The Following User Says Thank You to helmetface For This Useful Post: | rfinkle2 (08-09-2012) |
![]() | | #6 | ![]() |
Groans: 235
| Not Ranked : 0 score I'm with you 100%. The tables that control the post shift fueling are in that thread, but buried in with swas info. The thread title is definitely misleading. LOL
| The Following User Says Thank You to rfinkle2 For This Useful Post: | helmetface (08-09-2012) |
![]() | | #7 | ![]() |
| Engineered Tuning ![]() ![]() ![]() Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 8351 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,236
You can pull the timing to -3 but on the MS3 this does not have as big of an impact as the MS6. I assume you're not running VTA as that will also make the car stutter.
![]() | | #8 | ![]() |
(Thread Starter) | Not Ranked : 0 score The tables that were posted for the fuel comp. were the same as my ots values. My swas has been disconnected for a while now too. The only other thing i can see to do is to set the ign. timing limit min. from -3 to 0.
![]() | | #9 | ![]() |
Groans: 235
I don't foresee that being a problem, but have you noticed a -3 value in any of your logs that weren't post shift? Those tables were -13.5* from Mazda, and the -3 was a working change. I don't know that making the minimum advance 0 will fix the issue. (but may be worth a try). AHHHH! paulwalll... try this: scratch all of the above and change your fuel commanded max enrichment allowed to 11.0.
__________________ CPE ATMOSPHERE KIT / (GTX3071 w/ .82 hotside A/R) ● CPE HPFP ● CPE RMM ● CPE FMIC ● CPE TOW PLATE ● CPE TRITON CBE ● HTP 3" TIP ● HTP BATTERY RELOCATE● COBB AP ● GRIMMSPEED 3 PORT BCS ● COOLING MIST / DEVILS OWN METHANOL INJECTION ● DEFI Boost gauge ● TWM FULL REPLACMENT ● TWM M1 ABRAMS ● JBR SSP ● JBR RSB JBR TIG ● H&R COILOVERS● JUMPING JACKSON 3 BAR MAP HARNESS ● STOPTECH STAINLESS LINES ● AKEBONO EURPO 915a ● TANABE STRUT BRACE ● NEXTMOD M'z KIT CORKSPORT UNDERHOOD LED KIT ● GRAM LIGHTS 57 DR ● TOYO PROXES PLUS | |
![]() | | #10 | ![]() |
Just noticed your logs. Your boost takes a while to get back up - it should not spool by 4600 RPM. This definitely looks like a leak of sorts. Check the intake piping from the filter to the throttle body.
| The Following User Says Thank You to Lex For This Useful Post: | rfinkle2 (08-09-2012) |
![]() | | #11 | ![]() |
__________________ 2008.5 cwp ms3 | |
![]() | | #12 | ![]() |
Groans: 235
My apologies Lex for barging in. I see once in the logs the afr dips to low 9's and have had good luck with the max enrichment table keeping this from happening. The swas on my car activates on undulating roads sometimes (surprised me too), but that thread above has some fueling post shift fixes buried in it as well.
![]() | | #13 | ![]() |
![]() | | #14 | ![]() |
Groans: 235
Lex mentioned you were running vta and that could absolutely be making your car rich post shift. Yes. If the BPV isn't sealing, you could see erratic afr's, especially after it actuates (if not vta).
![]() | | #15 | ![]() |
(Thread Starter) | Not Ranked : 0 score Bpv is in full recirc.
![]() | | #16 | ![]() |
Groans: 235
| Not Ranked : 0 score It absolutely could be bpv related. I would yield to Lex though, and follow his advice. He is light years ahead of me in terms of hardware and tuning experience.
![]() | | #17 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yea im going to do a boost leak test again and try to move my intake piping by hand to try and simulate my car shifting, and see if any new leaks pop up.
| The Following User Says Thank You to paulwalll For This Useful Post: | rfinkle2 (08-09-2012) |
![]() | | #18 | ![]() |
The strange thing here is that once you shift, the boost hangs around the 3-5psi mark for a while and AFRs are very lean. This is for sure associated with your issue. The boost not building (and actually dropping in log 9) is a mechanical/leak issue. The AFRs are likely related. If you shift gently does it have the same behavior? How does it spool when going from 3-4. How does it behave if you sit at 3500 RPM or 4000 and punch it in 3rd or 4th?
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
Well i found that my occ is getting pressurized when i put the boost leak test on. The o ring seal in occ is a little worn out so it leaks air past 8 psi or so. I run a second pcv valve instead of a check valve, so i replaced that with a new one. Sill getting pressure to the occ probably air leaking past the piston rings. Would that be the cause of my issues? I found one other minute leak where the recirc hose meets the tip. Lex rfinkle2
![]() | | #21 | ![]() |
Definitely take care of the leak at the recirc hose - that will throw things off. For the OCC, are you boosting it through the intake or crankcase? If it's through the intake you need a valve that will seal before it. Like I mentioned I had some terrible stutter during shifting and couldn't figure it out. Turns out I had a leak between the TIP and intake and would unseat once the engine moved and BPV let off.
![]() | | #22 | ![]() |
Attachment 69774 Attachment 69775
![]() | | #23 | ![]() |
I'm stumped. Still having the shifting problem, ffs doesn't work at high rpm, and the rev limiter isn't working right. Everything mechanically on the car is fine, zero boost/intake leaks. The only thing i can think of is a sensor failing or there is a bug in the ap firmware. Here is another log of me holding the gas pedal down 100% for a few seconds. Super odd behavior. Sorry if i bother you Lex , but you seem to have alot of knowledge on troubleshooting. datalog1.csv
![]() | | #24 | ![]() |
![]() Join Date: Jan 2011 Location: sicily, Italy
Rep Power: 191 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 151
You try disabling FFS and LC? If its not working right than just get rid of it. Maybe it has something to do with the FFS RPM settings
__________________ 07 SILVER MAZDASPEED3 , COBB AP- COBB SS Downpipe- Cobb TIP- Devils Own stage 2 50/50 mix- Autotech internals- Mazdaspeed CAI- Denso ITV22- JBR RMM- JBR shift weight- JBR RSB, JBR Shifter bushings- JBR EGR delete- JBR thermal gaskets- Eibach pro kit lowering springs- Prosport boost gauge- 18 ADR gunmetal wheels W/ Nitto 555s |
![]() | | #25 | ![]() |
![]() Join Date: Apr 2009
Rep Power: 319 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 347
Groans: 195
Groaned at 34 Times in 24 Posts
in b4 OP buys a vette
![]() | | #26 | ![]() |
| Banned ![]() Join Date: Aug 2012
Rep Power: 0 ![]() ![]() Thanks: 0
Groaned at 42 Times in 8 Posts
did you notice this issue after installing the OCC by chance? Or was it something that crept up later on? What type of OCC are you running? I've heard a few issues on some cars depending on their OCC setups and how they had them installed that caused similar issues but there are obviously tons of variables to consider.... I'm just curious | |
![]() | | #27 | ![]() |
__________________ 2008.5 cwp ms3 | ||
![]() | | #28 | ![]() |
Groans: 195
bump for a friendly beaner
![]() | | #29 | ![]() |
Still having issues man?
![]() | | #30 | ![]() |
i just noticed you went BT. i wana go for a ride some time.
| BPV leaking or normal behavior | kish89 | MazdaSpeed 3 - Engine, Transmission & Driveline | 1 | 05-16-2012 10:25 AM |
| Odd WGDC behavior | Bucker | 2010 MS3 - ECU Computer Tuning | 33 | 01-28-2012 01:30 PM |
| Funny TPMS behavior | Hectik1 | MazdaSpeed 3/6 - Wheels & Tires | 5 | 05-20-2011 07:37 PM |
| Dashhawk Cold Weather Behavior | standic | MazdaSpeed 3/6 - ECU Computer Tuning | 6 | 02-02-2010 05:01 AM |
| Engine Behavior | NYSpeed | MazdaSpeed 6 - Engine, Transmission & Driveline | 7 | 04-14-2009 07:18 PM |
