  • 1 Post By SSinstaller
 Old 12-05-2018, 09:40 PM   #1
LukaszP's Avatar
Posts: 5   (View Stats)
LukaszP is an unknown quantity at this point
Default Possibly an ECU?
I was looking at buying a Mazdaspeed 3. It's a 2008.5 and I noticed that it has something by the battery where the ECU is located next to the battery. Can it possibly be some kind of aftermarket ECU?
LukaszP is offline   Reply With Quote
 Old 12-05-2018, 09:42 PM   #2
LukaszP's Avatar
Here is a closer picture. Seem to says "Kicker."
 Old 12-05-2018, 10:07 PM   #3
SSinstaller's Avatar
Posts: 3,922   (View Stats)
Groans: 56
Yes, that is an aftermarket ecu.
https://cdn11.bigcommerce.com/s-oqfw...=2?imbypass=on
LukaszP likes this.
Soon to be installed:
Thor Hammer (12-06-2018)
 Old 12-06-2018, 07:02 AM   #4
gotovato's Avatar
Posts: 206   (View Stats)
gotovato is a splendid one to beholdgotovato is a splendid one to beholdgotovato is a splendid one to beholdgotovato is a splendid one to beholdgotovato is a splendid one to beholdgotovato is a splendid one to beholdgotovato is a splendid one to behold
LOL. thats good. its a fuse holder man, from the aftermarket stereo that was probably in there at some point
2011 ms3 Cobb AP, Forge bypass valve, HPFP internals, Cobb downpipe, Custom fmic w/mishimoto core, Cobb RMM, Cobb EBC, KW coilovers, whiteline RSB, stop tech fluid, stop tech SS brake lines, hawk HP+ pads, ACT 6 puck clutch, ATP 3071r, HTP 3.5" intake, Damond catch can, TunedbyNishan
gotovato is offline   Reply With Quote
 Old 12-06-2018, 07:43 AM   #5
Jeff23spl's Avatar
Posts: 1,696   (View Stats)
Most of the time to alter ecu control on obd2 cars, it is something that just re-flash the oem ecu.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 12-06-2018, 09:26 AM   #6
mituc's Avatar
Posts: 3,507   (View Stats)
Groans: 111
Just on the right of that Kicker thing you can see the ECU connectors, they're so big and clear that they almost shout at you "I am here! I am here!!".
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 12-06-2018, 01:24 PM   #7
LukaszP's Avatar
I feel a little stupid lol. Thought it was some kind of aftermarket ECU. I’ve seen some speed owners do some stupid shit before, what can I expect. Thanks for the info! I’ll be on these forums a lot more frequently if I get it. 150k miles and really cheap. so definitely will need a rebuild soon.
 Old 12-06-2018, 05:31 PM   #8
whatsabrooklyn's Avatar
Posts: 62   (View Stats)
whatsabrooklyn is a splendid one to beholdwhatsabrooklyn is a splendid one to beholdwhatsabrooklyn is a splendid one to beholdwhatsabrooklyn is a splendid one to beholdwhatsabrooklyn is a splendid one to beholdwhatsabrooklyn is a splendid one to behold
do you have a subwoofer in your car? if not, see where the other end of that wire goes to... that looks like the power wire to the amplifier. if they took that stuff out of the car, you may want to see where that end leads to and possible remove it or take the fuse out or disconnect it... i would disconnect it to be on the safe side
whatsabrooklyn is offline   Reply With Quote
 Old 12-06-2018, 09:20 PM   #9
LukaszP's Avatar
I still haven’t gotten my hands on the MS3, and there is probably no possible way of me going to see the car. Technically it’s a “blind” purchase as for I only see the pictures of the car. It’s really cheap so I have nothing to really nothing to lose. If the worst comes, I’ll be parting it out. Although I’ll keep you updated when if I get it.
 Old 12-07-2018, 06:21 AM   #10
Jeff23spl's Avatar
you still talk about ''such a great price'' i hope it is below 4k?.
Do you have a video of it running if you gonna buy it without inspection and seeing it in person, you need at least to see if the engine isn't knocking....
A blown doesn't worth much....
Wife drive 2010 CX7
 Old 12-07-2018, 09:58 AM   #11
LukaszP's Avatar
Buying it for way below 4k. Don’t have a video of how it runs but it definitely runs. At this price, a blown engine are my expectations with this car.
Possibly getting a 3 seeyalaterbye Gen2 MS3 General Discussion 40 07-01-2012 11:24 AM
Page generated in 0.31047 seconds with 26 queries
