 Old 10-08-2019, 04:23 PM   #1
AlanSpeed3's Avatar
Posts: 4   (View Stats)
AlanSpeed3 is an unknown quantity at this point
Default Rich Trims P0172
Hi, If anyone could help I'd appreciate it. I have a 13 Speed3 fully modded that is throwing a P0172 code. Lt and St trims are full negative at idle pulling back fuel. I can drive for 300 miles without a light, as long as I don't sit at a stop for more that 40 seconds. I have cleaned the MAF and throttle body, changed plugs,air filter, WB A/F sensor and O2 sensor, cleaned the injectors, pressure tested the induction system from MAF outlet the the intake manifold, changed otc maps from Stage 1, 2 and 3 and removed access port completely to revert back to factory software. I have also modified the throttle inlet snorkel to accept the MAF directly to eliminate the boost system completely. (I thought of this after Cobb T.S. insisted that i have a post cat leak) All these test and procedures still result in high negative trims at idle and a P0172 within 2 minutes of idling. Also, with my Autel scantool hooked up at cold start, all pids seem to be normal for the first 5 minutes of running time, with no cel setting. At around 5 minutes and 160 f. the Equivalency ratio, A/F ratio and fuel go full rich. I have included data logs. Thank you for your help.
AlanSpeed3 is offline   Reply With Quote
 Old 10-08-2019, 09:09 PM   #2
MSMS3's Avatar
Posts: 2,690   (View Stats)
Groans: 150
Is your MAF sensor an OEM part and specifically the right OEM part number? Aftermarket sensors don’t work right and our sensor is a different part number than for the non-turbo engine.
We have a similar issue with the primary wideband O2 sensor. OEM only seems to work properly. We can use a lot of non-OEM parts but, these two sensors need to be OEM and specific to this engine.
Most people throwing 0172 code have a faulty MAF sensor or have replaced it with non-OEM for our engine.
Data logs are not showing up for me.
2013 GEN PU CEL P0172 BadBish76 2010 MS3 - Troubleshoot/Diagnostics 6 09-08-2015 08:22 PM
Running rich, crazy trims, overboost HELP william1 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 38 11-21-2014 08:11 AM
Help p0172 code Speedster13 2010 MS3 - Troubleshoot/Diagnostics 10 10-22-2013 10:22 AM
reasons for rich fuel trims leadf00t MazdaSpeed 3 - Engine, Transmission & Driveline 21 05-25-2010 11:24 AM
Page generated in 0.23694 seconds with 21 queries
