![]() | | #1 | ![]() |
![]() Join Date: Aug 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 160
Groaned at 3 Times in 1 Post
(Thread Starter) | Not Ranked : 0 score I can personally say that I have tried many of the 'tricks' that should have logically worked (or that would.. you know... work on ANY OTHER CAR). I have tried adding fuel. I have tried lowering boost. I have tried retarding ignition timing. I've swapped to colder plugs. I've checked and rechecked for boost leaks. 99% of the time, I can nail the throttle at any RPM in any gear and have no problems. But at random times, I will go WOT from a cruise, car will buck/stumble, sometimes badly, with a sound like a light backfire from the exhaust, I will usually see a big puff of smoke (hard to tell but it looks greyish to me which is kinda scary), and usually will see big KR numbers on the AP. I can go out, find a nice deserted area, and do pull after pull after pull with no issue. But when I'm just driving around normally, and then need to speed up suddenly for some reason, this is more often than not when I have this happen. The theory that SEEMS to fit most is the idea that gunk is getting sucked up from the PCV or whatever during normal driving, and then suddenly getting on it causes this stuff to get sucked up and choke the engine. But that's just one of the plausible theories out there. I am a po'bastard and have yet to be able to install any kind of PCV fix, catch can, or everyone's favorite meth injection, which, if the gunky theory is correct, I guess this is the only way to fix this. But for self-tuners... have any of you guys found, for 100% certain, another culprit that I should be looking at? What have we as a group learned, what do we know for sure, and what are we still not sure about? EDIT: oh yeah I should mention... I am not even at ALL concerned about part throttle or cruising KR anymore, and this is not the concern of my post. I've definitely read enough info that suggests that this really is nothing to be worried about. I am talking strictly about WOT knocking, and not even necessarily KR on the AP, but that gut wrenching stutter, big puff of smoke, and sounds like an engine about to convert internal parts to external parts...
__________________ '07 Speed 3 GT, Red, MSCAI with flow straightener, 2nd cat delete, JBR TMM, AWR RMM, and Cobb AccessPORT running custom 20% e85 tune. Last edited by bast525; 11-08-2009 at 05:36 PM. |
| The Following 2 Users Say Thank You to bast525 For This Useful Post: | 2007speed3 (11-08-2009), SpeedSixxx (11-11-2009) |
| Always Blasted ![]() Join Date: Jul 2009 Location: North NJ
Rep Power: 680 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 309
Groans: 34
Groaned at 274 Times in 34 Posts
| Not Ranked : 0 score FMIC, oil catch can, MAF mesh, and a protune.
__________________ 07 Speed 6 GT Cobb AP Stage 2+TIHSF+TMIC 93 Octane, ETS 3.5'' TMIC, Cobb Short Ram Intake, Cobb Turbo Inlet Pipe, Turbosmart Dual Port Blow Off Valve, SU Test Pipe, Custom CPE/Magnaflow Exhaust, Corksport Strut Brace, TWM Stage 2 Short Shifter, TWM Weighted Desert Eagle Shift Knob, AWR Transmission Mount, SU Base Bushings, SU Rear Motor Mount, Optima Yellowtop Battery, PIAA Plasma Ion Fogs, EBC Red Brakes, Denso ITV22s .28 Gap, Prosport Boost Gauge, RPM Sport Springs, Bilstein Shocks, SPC Balljoints, Continental Extreme Contact DWS AAA XL, Pirelli Sottozero snow tires, 5zigen ProRacer GN+ 18x8.5. |
(Thread Starter) | Not Ranked : 0 score That's it? that's the guaranteed recipe for no more knock or no blown engine? What about meth? What about removing the balance shaft? Who's having the most success with tuning themselves using ATR? Not being sarcastic... these are all things I've read that someone or other has suggested COULD be causing the problem. I just got done reading through SLS MS3's blown engine thread... I want to think that because I am so lightly modded (intake and AP) that I am safe, but when I am leaving a light or whatever and get on it in 1st/2nd/3rd gear, and the car bucks and I hear sounds no engine should make, and a big puff of smoke out the back... I don't think I'm safe either way.
__________________ '07 Speed 3 GT, Red, MSCAI with flow straightener, 2nd cat delete, JBR TMM, AWR RMM, and Cobb AccessPORT running custom 20% e85 tune. |
![]() | | #4 | ![]() |
| Banned ![]() Join Date: Jun 2008 Location: northern nj
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 350
Groans: 49
| Not Ranked : 0 score maf mesh is bull shit |
| The Following 7 Users Say Thank You to boosted3 For This Useful Post: | 2007speed3 (11-08-2009), aaronc7 (11-08-2009), E4Performance (11-18-2009), Fobio (11-09-2009), FreeFlyFreak (11-17-2009), RayRayBauder (11-10-2009), wakeboarddude (11-28-2009) |
![]() | | #5 | ![]() |
![]() Join Date: Jun 2008 Location: Raleigh NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
Groaned at 37 Times in 23 Posts
| Not Ranked : 0 score I drive 120 miles a day roundtrip for work and I just ignore the cruise knock. Its just the ecu trying hard squeeze out as much timing as it can for good gas mileage. How did I confirm this? Here are some observations: 1. The knock doesn't just show up then disappear. It will throw 4 or 5 degrees (supposedly) and slowly work its way down to zero like its testing itself. 4 or 5 degrees of retard when ur running 40+ isn't shit and you won't feel it. 2. Instead of lifting when I see KR I started to just let it ride. After a few times of rolling down to zero, it actually stopped KR'ing at cruise. When you lift, it doesn't give the ecu a chance to learn so it keeps trying. 3. According to the mazda DISI training doc, the ecu can only pull up to 6 degrees of timing during an actual detonation situation. I've seen 6+ kr during 80mph cruise quite a few times without the car stumbling or hesitating. |
| The Following 8 Users Say Thank You to smakdown61 For This Useful Post: | boosted3 (11-08-2009), DaleNixon (11-09-2009), djthom (11-09-2009), E4Performance (11-18-2009), Fobio (11-09-2009), NRSpeed (11-18-2009), nytmar3 (11-08-2009), tunersteve (11-17-2009) |
![]() | | #6 | ![]() |
(Thread Starter) | Not Ranked : 0 score Smak... thanks man you actually pointed out a glaring error in my original post... I shoulda mentioned I am not at all talking about or worried about PT KR... OP edited for clarity
![]() | | #7 | ![]() |
| Not Ranked : 0 score Ah I see what you were saying. Yeah its certainly possible if you aren't running a catch can that under boost its forcing that gunk into your combustion chamber. Honestly, after using ATR to adjust my tune and adding an occ and one step colder plugs I don't have any WOT knock at all. |
![]() | | #8 | ![]() |
![]() Join Date: Jan 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 952
| Not Ranked : 0 score All of a sudden for the past 2 days i would get 3-6kr when driving like a granny not in boost just cruising along. I decided that to reload the map and of course that stopped it, but im sure once the computer relearns again it will reappear.
![]() | | #9 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
Groaned at 24 Times in 6 Posts
| Not Ranked : 0 score I dont have knock, cant help you here. Try TORCO |
| The Following 2 Users Say Thank You to slo4now For This Useful Post: | 2007speed3 (11-08-2009), FreeFlyFreak (11-17-2009) |
![]() | | #10 | ![]() |
| Not Ranked : 0 score |
![]() | | #11 | ![]() |
Groans: 49
| Not Ranked : 0 score I get crazy random knock sometimes just crusing like u said dosent effect anyting or i dont hear anything,but somedays it wont even kock at all,I dont even worry about that anymore.Unless im wot in boost thats the only time u really wory about that knock.... |
![]() | | #12 | ![]() |
![]() Join Date: Mar 2008 Location: State College, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,091
Groaned at 9 Times in 7 Posts
__________________ ![]() 07 Mazdaspeed3 | |
![]() | | #13 | ![]() |
![]() Join Date: May 2008
| Not Ranked : 0 score Turn off the KR monitor on your dash hawk......no more knock. If your not hearing it, I wouldn't worry about it.
__________________ Smoking Car FTL =( |
| The Following 4 Users Say Thank You to nytmar3 For This Useful Post: |
![]() | | #14 | ![]() |
![]() Join Date: Aug 2008 Location: jersey
Rep Power: 609 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 388
![]() | | #15 | ![]() |
Groans: 34
| Not Ranked : 0 score i wasnt really saying that was the solution, i just gave 3 options which claim to aid in no more knock
![]() | | #16 | ![]() |
| Eatin' Your Tuna ![]() Join Date: Feb 2008 Location: Nator HQ - San Diego, CA
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,602
Groans: 244
This is the answer and you can verify this simply with a dashawk if you are in doubt. You can set the visual alert for knock and do color changes for each range of knock (degrees) ... Mine starts off Dark green and works itself to yellow. What is funny, no one ever believed me that part throttle knock is something to be worried about. Its nothing more then the computer trying to adjust timing to match the best mpg... Ive also verified this with the MPg computer on the car.. As your phantom knock begins, look at the mpg readout and watch it adjust
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | ||
| The Following 2 Users Say Thank You to Haltech For This Useful Post: | jahman (11-17-2009), SpeedSixxx (11-11-2009) |
![]() | | #17 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score it is or is not somthing to worry about? lol |
![]() | | #18 | ![]() |
![]() Join Date: Aug 2008 Location: Medford, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 625
| Not Ranked : 0 score It is not something to worry about. Mine only does it during cruise in 5th and 6th gears. 5th more than 6th actually. I'll get a very infrequent .3-.7 during WOT, which I usually can't reproduce from one datalog to another. I was getting WOT stumble and it turned out to be my plugs. I was using ITV24's and had about 20k miles on them. Replaced them with ITV22's and no more stumble. I'm going to start changing my plugs every 6 months. I put 24k miles a year on the car. For $36 a set, it's a no-brainer. This car is not easy on spark-plugs at all. You can't go 100k miles a set of plugs with this car like you can in a Honda motor. A "wrenching stutter and a big puff of smoke" doesn't sound like a pre-ignition problem to me. It sounds like spark blowout, but that's just my opinion. The puff of smoke is you going rich from the misfire. I also try not to "nail" the throttle. If you've gotta nail it, you've gotta nail it, but I try not to make it a habit. I ease into it to let the fuel catch up to the fucking pint sized turbo we have. I'm not talking about driving like granny, but giving it a potato or two going from cruise to WOT rather than putting your foot through the firewall may help you avoid some KR, especially below 3,000 RPM.
__________________ 08.5 CWP MS3 - Cobb AP *Stage 2* ATR with a street tune - JBR Power Path Stage II Short Ram Intake - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - TSW Nurburgring Machined 18x8.5 Wheels - FIREHAWK INDY 500 - SIZE: 235/40R18 - Cobb RSB - Motorcraft XT-M5-QS in the tranny! |
![]() | | #19 | ![]() |
| Not Ranked : 0 score I wouldn't worry about low load KR. Only KR I would worry about is WOT. |
| The Following User Says Thank You to Lex For This Useful Post: | Fobio (11-09-2009) |
![]() | | #20 | ![]() |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
| Not Ranked : 0 score That's basically the assumption I've taken since getting a SRI and monitoring thru the DH...once I confirmed I wasn't the only one, I never looked back.
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
![]() | | #21 | ![]() |
![]() Join Date: Mar 2008 Location: In a house
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54
| Not Ranked : 0 score ive always let off the gas when im cruising at 70+ and see high kr of 5 or so. next time ill let it ride. my whole ride up to the SU meet i was getting kr but i would let off the gas when ever my warnings went off. so if tahts true then that explains why i got it almos the whole way up. the ecu couldnt learn and adjust because i was letting off the gas.
__________________ 7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance |
![]() | | #22 | ![]() |
The fact that engines let go at light loads has nothing to do with KR at light loads. The damage is done during high loads and experiencing abnormal combustion. | |
| The Following User Says Thank You to Lex For This Useful Post: | wette460 (07-29-2010) |
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score yeah I did need to clarify... I am really no longer concerned about part throttle KR. I have 19,000 miles on my current plugs... guess it would not hurt to change them. I've had misfires from spark cut before on other cars (bad plug wires usually in those cases) and it was not as violent as this, but I won't argue that it is a possibility. The thing that strikes me is how RARE and RANDOM it is. There is no pattern, it can seemingly happen at any time, it tends to happen usually in low gear... 1st or 2nd, right as boost builds. People have said it's my fuel pump but the times I've ever happened to catch a log of this, fuel pressure was fine...
![]() | | #24 | ![]() |
Groans: 244
| case closed, fookers... lol
![]() | | #25 | ![]() |
![]() Join Date: Aug 2009
Rep Power: 0 ![]() ![]() ![]() Thanks: 23
| Not Ranked : 0 score Lex, What about audible part throttle knock? I'm not talking about KR. Actual knock itself. I've heard the worst knock in my life at 10-20% throttle when going from vacuum to just starting to boost when accelerating up an on-ramp. Sounded like mini-firecrackers. Could this be bending rods or causing other damage that would cause the engine to let go later? My understanding is that any audible knock is really bad for an engine whether it's part throttle or full throttle.
__________________ 2006 Mazdaspeed6 33k miles - stock | |
![]() | | #26 | ![]() |
![]() Join Date: Apr 2009 Location: Bethpage, New York
Rep Power: 4481 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,850
Groans: 778
i never once stuttered or any of that u talk about. and I never hear any knock unless i suck at taking off from a light in first and i almost stall (almost never) ..only when i shut the car off does it sound like a 1920's car knocking...but i think thats all speed motors...
__________________ 2003 SilverStone Grey Honduh S2000 ![]() ![]() | |
![]() | | #27 | ![]() |
![]() Join Date: Oct 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
| Not Ranked : 0 score Was on a 20 mile drive today. Was in 6th about 75 mph and went wot to pass someone and the dashhawk flashed a knock event, but I didn't see it in time to see what kind of knock it was. I deffinately felt a pause in acceleration. Should I worry? Completely stock except for second cat delete. |
![]() | | #28 | ![]() |
Groans: 778
do urself a favor and continue to hit the gas while the knock warning goes off...ur car will learn and this wont happen as often
![]() | | #29 | ![]() |
| Not Ranked : 0 score On way home I nailed it a few times and no knock this time out. I guess it learned it's lesson. |
| The Following User Says Thank You to stevessvt For This Useful Post: | SpeedSixxx (11-15-2009) |
![]() | | #30 | ![]() |
![]() Join Date: Sep 2008 Location: Phoenix, AZ
Rep Power: 1352 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 813
Personally during long cruises I ease onto the throttle every now and then and hit a bit of boost to clean it out. If in the end it does hold merrit, you don't want this happening at WOT being sucked up very quickly and at full timing.
__________________ Some things. | |
![]() | | #31 | ![]() |
| Not Ranked : 0 score So was driving again, was only a few minutes on the road. At 60 I rolled in to it in 6th to pass someone. Heard a ping, felt the car slow a not and saw the DH flashing a 7.0 KR! WTF? I am bone stock except second cat delete! I am scared shitless I'm going to be driving somewhere and it's going to puke it's guts out. Coincidence? I Just realized I put $20 in gas on Sunday just before the first knock event. Last edited by stevessvt; 11-17-2009 at 12:06 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #32 | ![]() |
| KR....i haz it ![]() Join Date: Apr 2009 Location: Philadelphia, PA
Rep Power: 1381 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,652
Groans: 166
| Not Ranked : 0 score i hate that sound. this quote belongs in the thread" you know you have a speed 3 when..."
__________________ Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts | CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp ![]() |
| The Following User Says Thank You to Blackspeed For This Useful Post: | SpeedSixxx (11-17-2009) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score This is pretty much what I thought also. I've also learned to ignore the KR when entering the next gear. Seems to be the same thing as part throttle cruise KR. It learned and now it doesnt do it much at all. ALso whats interesting is that on my morning commute to work, I can predict EXACTLY when KR is going to happen. It happens in the same spot every day all the time. It hits about 4.6 and does the count down. So it seems to have some kind of "schedule" to it probably related to distance and not time, as I've gone in various traffic conditions, got behind someone really slow, or drove really fast and it still happens at the same spot.
![]() | | #34 | ![]() |
| Not Ranked : 0 score So am I being a drama queen? Should I not over think it? |
| The Following User Says Thank You to stevessvt For This Useful Post: | SpeedSixxx (11-17-2009) |
![]() | | #35 | ![]() |
![]() Join Date: Nov 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,325
My PT Knock 'Experiment' - Mazda Forums Glad to see that we're on to something. Honestly, local guys who don't monitor KR don't seem to have a problem. I actually am going to raise my warnings on the DH above 6 for the low end of the alerts, since anything above that should be legit (and bad).
__________________ 2011 Mustang GT ![]() | |
![]() | | #36 | ![]() |
![]() Join Date: Oct 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
| Not Ranked : 0 score I have to agree with Nytmar. I think too much info can be a bad thing. Knock and pinging can be heard pretty readily when it occurs. These ecu tuned cars (i miss the old school "tuning") are tweaked for ragged edge mileage etc, so that thresholds are often being crossed that while visible on a Dashawk, are negligable...in "most" cases. (and on cars with stock components/tunes) Sometimes, ignorance is bliss. My 2001 Rodeo has pinged under "float" conditions...(steady speed, barely on the throttle) since mile 1. Damn thing wants premium fuel, sooooo thats what it gets. The tune is an example of a manufacturer cutting parameters tooooooo close. Ken |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Today i was in 5th at around 3100 3200 rpms, kr shot to 5.9 and held it for about 1 mile, it did not change at all. I hit a bump in the road and it went away, my throttle position and rpms did not change tho, so wtf.... |
![]() | | #38 | ![]() |
![]() | | #39 | ![]() |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45886 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
| Not Ranked : 0 score Been trying this this last couple of days, and sure enough my PT knock has been slowly disappearing. Down to about a quarter of what it was 3 days ago. |
![]() | | #40 | ![]() |
| Not Ranked : 0 score Curious,...if a rod was tweaked, would you pull less vacuum at idle?
Last edited by stevessvt; 11-20-2009 at 06:36 AM. Reason: MSF Database - Automerged Doublepost | |
| Fail: Defect reportedly causing NYC car registration stickers to unstick | Haltech | Automotive News | 0 | 10-15-2009 06:50 AM |
| Hyundai's $1.49 fuel promo causing traffic jams at gas stations across the country? | Haltech | Automotive News | 0 | 07-01-2009 05:10 PM |
| Raising MAF tables causing slight stumble in acceleration? | bast525 | Cobb ATR Support | 8 | 06-19-2009 05:46 PM |
| Strage rattle at WOT causing phantom KR | aaronc7 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 39 | 06-15-2009 08:28 PM |
| Male hormones causing credit crunch | Haltech | Computers & Technology News | 0 | 04-15-2008 05:51 AM |
