  • 1 Post By I Love Brownies
 Old 07-02-2011, 02:37 PM   #1
Coats's Avatar
Posts: 580   (View Stats)
Coats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the world
Default Something is wrong
I recently switched to a Stage2 map on my AP after adding the COBB DP. the car is sputtering around 4k and up at WOT. It was recommended by COBB over the telephone that I get a HFFP from cp-e. I switched back to the Stage1 map as a precaution and everything seems fine. After reading some threads I see that there are many enthusiasts on this forum that can read logs taken from the AP. Will someone please help me out by telling me what parameters I need to log. I can figure out how to post the logs and have a more seasoned member read them and determine where my problems might be. Thanks
2013 Dodge Ram Laramie
GONE 2009 335i xdrive coupe COBB AP V3 CPe DCI
SOLD 2009 FREEKED Mazdaspeed3 GT
Coats is offline   Reply With Quote
 Old 07-02-2011, 02:39 PM   #2
Eth Fiend
phate's Avatar
Posts: 6,931   (View Stats)
You can log the default parameters to get a good idea. You can then open it with Excel, or post the .csv here for us to look at.
It is likely to be the HPFP though.
 Old 07-02-2011, 02:40 PM   #3
m4tic's Avatar
Posts: 4,922   (View Stats)
your fuel pump cant take the flow demand that the DP and stage2 tune present
2007 MS6 w/ Cheez
 Old 07-02-2011, 02:43 PM   #4
oh10speed3's Avatar
Posts: 1,119   (View Stats)
oh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the world
Groaned at 74 Times in 30 Posts
you need a fuel pump for stage 2..
//Stage 1 & Done\\
oh10speed3 is offline   Reply With Quote
 Old 07-02-2011, 03:05 PM   #5
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
I too was just having that problem. Get hp fuel pump internals, don't WOT until you do, ESPECIALLY since you have no idea how to monitor or log your parameters!
07 MS3
The original Genpoo Hater
 Old 07-02-2011, 03:16 PM   #6
WorstEpEver's Avatar
Posts: 418   (View Stats)
WorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the world
Sounds like a fuel PSI problem, but can't be sure. Logs will help.
You can log just the default parameters. Find a nice clear road and do a 3rd gear WOT pull from 2500-6500 RPM. Should take you from about 30-75mph. If you can, do 3 logs as that will help rule out inconsistencies.
BTW, have you calibrated your MAF?
09 MGM Sport
AP (MIA ) / Internals / TMIC / CAI / TIH / Downpipe / CBE / Short shifter / RMM / RSB
WorstEpEver is offline   Reply With Quote
 Old 07-02-2011, 03:19 PM   #7
I Love Brownies's Avatar
Posts: 3,791   (View Stats)
I Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the world
Groans: 371
Groaned at 62 Times in 39 Posts
sounds like your blinker fluid is low
Coats likes this.
I Love Brownies is offline   Reply With Quote
 Old 07-02-2011, 09:27 PM   #8
Coats's Avatar
Thanks guys I will get some logs up here within the next 48hrs. @WorstEpEver, I have never calibrated my MAF. I will research on here how to go about completing that unless you have a straightforward way for a newb to go about it. @ms307nm...I ruled out the blinker fluid, I was thinking I might need to take an exhaust sample...
 Old 07-02-2011, 09:31 PM   #9
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
read alibor's guide the Maf cal is very easy and don't do pulls until you get your fuel pump
 Old 07-02-2011, 09:37 PM   #10
kunfu's Avatar
Posts: 467   (View Stats)
kunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the worldkunfu is the leader of the world
Groans: 56
Donate!
Speed 3 2007:
NATOR NY mod. SURE SRI and TIP, OBX Test Pipe, SURE RMM, KMD Internals, JBarone SSP, Koni FSD's,Solid shifter bushings, Cobb AP, Stainless brake lines, EGR delete, OCC, HIDs, IV-22's, Turbo timer.
kunfu is offline   Reply With Quote
 Old 07-02-2011, 09:53 PM   #11
zpele's Avatar
Posts: 1,654   (View Stats)
zpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the world
Groans: 354
Groaned at 213 Times in 109 Posts
I would suggest you be very careful with that AP until you fully understand how to do at least basic tuning. You can very easily fuck up your car with the AP if you try and either modify shit or load the wrong map for your mods.
The AP does give warning signs when your car doesn't like the tune but you kind of have to know what to look for. Here is the link to Abilor's guide. I would suggest read it multiple times as you probably won't understand half of it the first time:
http://www.mazdaspeedforums.org/foru...e-noobs-83959/
2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now)
2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy
zpele is offline   Reply With Quote
 Old 07-05-2011, 03:15 PM   #12
Coats's Avatar
Appreciate all the advice. I am re-reading Abilors guide.
Something wrong thanox2 Mazdaspeed3/6 General Discussion 0 04-21-2009 09:25 PM
Page generated in 0.65298 seconds with 29 queries
