-   MazdaSpeed 3/6 - ECU Computer Tuning (http://www.mazdaspeedforums.org/forum/f9/)
-   -   Stage 1 First Logs (http://www.mazdaspeedforums.org/forum/f9/stage-1-first-logs-132705/)
Tyhackman15 12-12-2012 04:27 PM
Stage 1 First Logs
I've attached my first log with the v231 OTS stage1 93 stock intake map. Boost is a little low (targets 16.5) and it was lower still on the stock logs I ran. Also AFR seems a little lean to start but then evens out.
HPFP seems to be holding well, I will run a few more logs tonight to compare before I start tweaking in ATR.
The part that I was thrown off by is the RPM fluctuation from 5k to redline. I could feel it slightly in the car as well. Any ideas? Also anything else you point out about the log is greatly appreciated.
-Tyler
ms3blackmica 12-15-2012 01:43 AM
The v2.31 OTS maps target 11.6 AFR so that is normal. I did not see any RPM flucation in the log you posted. It kept increasing..
Page generated in 0.16587 seconds with 11 queries
