Notices
  • 1 Post By Whiteboy
 Old 10-22-2012, 09:03 PM   #1
dimka505's Avatar
Posts: 22   (View Stats)
dimka505 will become famous soon enoughdimka505 will become famous soon enough
Groaned at 9 Times in 2 Posts
Default Stage 2?
Hey guys, so im really interested in doing a stage two on my 08 ms3, this week my cobb ap came in and so did ingen CAI, this coming Thursday im ordering corksport RP,DP,and CBE. question is would i be safe to run this, anything else i would need (according to cobb i need to upgrade the fuel pump) and which map would work best.
would Really appreciate if i got some help.
thanks MSF members
dimka505 is offline   Reply With Quote
The Following 4 Users Say NO Thank You to dimka505 For This Un-useful Post:
Geo13 (10-23-2012), J'sSpeed3 (10-23-2012), midoritora (10-23-2012), MS3G35 (10-23-2012)
 Old 10-22-2012, 09:05 PM   #2
m4tic's Avatar
Posts: 4,565   (View Stats)
Groaned at 22 Times in 20 Posts
fuel pump first... then all that shit...injen = p00p; get a JBR whale penis.
2007 w/ Cheez
// COBB AP // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Prosport Elec Boost Gauge // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob
m4tic is online now   Reply With Quote
The Following 2 Users Say Thank You to m4tic For This Useful Post:
Geo13 (10-23-2012), MS3G35 (10-23-2012)
 Old 10-22-2012, 09:10 PM   #3
Whiteboy's Avatar
Posts: 1,926   (View Stats)
Whiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the world
Fuel pump first then do whatchawanna...oh yeah, read the stickies for the love of god
Geo13 likes this.
~My Mod List: ETS TMIC; CP-E SRI; COBB TIP; CP-E DP; CP-E RMM; CP-E Safe Seals; ITV-22's; GHL SS CBE; TWM STS w/bushings; Autotech HPFP Internals; AP (Stratified by Lex); Matt Damond OCC; CP-E Triple Gauge Pod w/ Prosport Premium Boost, AFR, and Oil Pressure Gauges; JBR Eliminator Shift Knob~
Whiteboy is offline   Reply With Quote
The Following User Says Thank You to Whiteboy For This Useful Post:
Geo13 (10-23-2012)
 Old 10-22-2012, 09:10 PM   #4
Naaman's Avatar
Posts: 318   (View Stats)
Naaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the worldNaaman is the leader of the world
Fuel pump is a must. This isn't one of those things that you "need" like its optional. This is something you NEED or else you'll likely blow your shit up one day.
Naaman is online now   Reply With Quote
The Following User Says Thank You to Naaman For This Useful Post:
Geo13 (10-23-2012)
 Old 10-22-2012, 09:15 PM   #5
evolizzee's Avatar
Posts: 563   (View Stats)
evolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the worldevolizzee is the leader of the world
The engine's Rear Motor Mount needs to be beefed up. Don't run any stage 2 maps until the fuel pump is upgraded!
2011 Blue Mica 50% E85
COBB:AP, DP, SRI, TIP, OCC // Blitz Steel Mesh Filter // SURE: RMM, Boost Tubes, Counter Weight, Shift Anchors, AGS Knob // JBR : Tranny Mount // PT-P: HPFP, Rail Valve, PCV Vent // Forge BPV V1 // ETS 3.5" TMIC // NGK IXs // EGR Delete // Resonator Delete // Redline Shock Proof Gear Oil // Syn Power 5w-40 // Koni Yellows // H&R Sport Springs // SPC Camber Arms// Spec: Stage 3 SR Clutch, 12lb Flywheel
13.3@112mph
evolizzee is offline   Reply With Quote
 Old 10-23-2012, 08:23 AM   #6
dimka505's Avatar
Thank you...
 Old 10-23-2012, 08:32 AM   #7
Geo13's Avatar
Posts: 1,006   (View Stats)
Geo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the world
Groans: 110
Groaned at 8 Times in 7 Posts
Don't do anything until you (re)SEARCH first...
Don't get all emotional cause your being told to do so.
Don't say "I did search already" cause if you did I wouldn't have stumbled upon this waste of bandwidth.
Who am I kidding....do what you want & good luck with that.
Release the Kraken!!
SPONSORED BY MY WIFE- 2010 Mazdaspeed3 Black Mica (DeadPool): COBB AP Stage 2+(Custom skeurHYPNOTICton Tune), SURE AEROS, SIDEWINDER, RETURN, CHARGE TUBES, TORQ R3 RMM (STREET), IM & TB TIG, SHORTCUT, COUNTERWEIGHT, TVS Caps, S.U Edition TURBOSMART 50/50 BOV, JBR70D TMM & PMM, RSB, OCC, EGR Block Off, Mudflaps, Tanabe Strut Tower Bar, Moddiction Anvil, TWM Full Replacement Shifter, Fortune Auto 500 Coilovers, Rolled & Slighty Pulled, SPC Adjustable Camber Arms, Autotech Internals, Denso ITV24, ETS TMIC, UR Catted Down Pipe & Resonated Test Pipe, Corksport CBE, GrimmSpeed 3 Port EBCS, Proto Tuning AP Holder, ProSport EVO Boost & AFR Gauge, Ultragauge Classic, Block8Head Dual Vent Pod, DDM Lows: 35w/6K & Fogs: 35w/3k HIDs, Headlight Armour Yellow Fog OverlaysiNATORva
COMING SOON: NOT A DAMN THING CAUSE I GOT ANOTHER TICKET!
2 Reckless By Speed + 3 Speeding = Mazdaspeed3 (no more parts and a pissed off wife)
Geo13 is offline   Reply With Quote
 Old 10-23-2012, 11:13 AM   #8
ms3blackmica's Avatar
Posts: 3,950   (View Stats)
INSTALL FUEL PUMP INTERNALS FIRST
please
2009 MS3 GT: Stock HID's and an NJSPEED3 Mani
"NJ Nator the home of makeshitfit technology" - voltron
"I didn't build it hoping for your approval...I built it because it meets mine."
ms3blackmica is online now   Reply With Quote
 Old 10-23-2012, 11:17 AM   #9
Constantin's Avatar
Posts: 2,524   (View Stats)
Constantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the world
"dimka" = Дима?
2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq
Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arm | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors
Constantin is online now   Reply With Quote
 Old 10-23-2012, 03:30 PM   #10
dimka505's Avatar
да dimka это дима lol
 Old 10-23-2012, 03:35 PM   #11
Constantin's Avatar
Привет! А ты откуда и какими судьбами тут?
 Old 10-23-2012, 04:01 PM   #12
baby squirrel sexy mofo
breakfstincluded's Avatar
Posts: 2,769   (View Stats)
Groans: 185
Groaned at 16 Times in 16 Posts
AK47
The Following 2 Users Say Thank You to breakfstincluded For This Useful Post:
easy (10-24-2012), Geo13 (10-23-2012)
 Old 10-23-2012, 04:03 PM   #13
Constantin's Avatar
Originally Posted by breakfstincluded View Post
AK47
 Old 10-23-2012, 04:19 PM   #14
dimka505's Avatar
я с harrisonburg virgina, да вот решил stage two зделат чтоб брата всавит lol (его stage two 2012 wrx) и проста для инереса. пока жена розрешает. i see u got some stuff done to ur speed, how r the auto tech internals? and ur speed ingeneral?
in guessing ты Константин?
Last edited by dimka505; 10-23-2012 at 04:19 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-23-2012, 04:31 PM   #15
dead-zone's Avatar
Posts: 336   (View Stats)
dead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the world
Groaned at 21 Times in 10 Posts
As some people already mentioned it. Fuel Pump internals is a must. Get AutoTech as most people so you do not have to deal with failures. Get a SRI instead of CAI. If you decide to start tuning, actually even now, consider spark plugs. Denso ITV22 one step colder, gapped to 0.28 are one of the best options for your DI beast.
dead-zone is offline   Reply With Quote
 Old 10-23-2012, 04:46 PM   #16
AzHiAziAm
PreyStayShun's Avatar
Posts: 423   (View Stats)
PreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the worldPreyStayShun is the leader of the world
This is scary.
None the less...here you go dude:
COBB Tuning - MAZDASPEED AccessPORT
^^^All the maps you need for the Injen.
Would still get a good idea to get a tune. These are ots maps, it'll play nice w/your upgrades...but not as nice as it should.
Oh...and I'm with dead-zone on Denso's, except .028" (as opposed to .28" as noted above.) I just got my plugs for like $35 shipped.
Car- 06' MS6
Mods:
***Some
Tune:
skiTOON in progress.
Car- 08' MS3 SOLD
Mods:
***Nothing Special
Tune:
***Ski85 Toon'd 50/50 Mix- VD @316/369- W/OUT Timing , 1st Map (My DD Map)
That's madness. I don't have pieces LynzeC
PreyStayShun is offline   Reply With Quote
 Old 10-24-2012, 12:19 AM   #17
XerocX's Avatar
Posts: 455   (View Stats)
XerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond repute
Originally Posted by PreyStayShun View Post
This is scary.
Where did you order your plugs from?
2009 CWP MS3
COBB Accessport, COBB SRI, HTP TIP, PG FMIC, Autotech internals, Guardian Angel, TurboSmart Dualport BOV (VTA), CNT Catless DP + CBE, JBR Dogbone rmm, JBR RSB, Sure Shortcut, H&R Springs, CPE tow plate, MRR GT-1 18x8.5+ 35
XerocX is offline   Reply With Quote
 Old 10-24-2012, 03:34 AM   #18
bostongeorge's Avatar
Posts: 55   (View Stats)
bostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond reputebostongeorge has a reputation beyond repute
Try here: EDGEAUTOSPORT
@eric@edgeautosport
"In the end, there can be only one"
COBB AP STAGE 2 // COBB TBE // COBB TIH // AUTOTECH INTERNALS // KSPORT KONTROL PRO COILOVERS // JBR RSB // JBR RMM // DENSO IRIDIUM ITV22//MAISONVI SS SHIFT KNOB
2008 Black Mica MS3
bostongeorge is offline   Reply With Quote
Quick Question about Stage 1 vs Stage 2 Roguevice 2010 MS3 - ECU Computer Tuning 11 07-16-2011 12:58 PM
Interesting look at Stage 1 + SF vs. Stage 1 + MSCAI2 maps, similarities and differences bast525
Cobb ATR Support
4 05-24-2009 06:52 PM
Page generated in 0.43313 seconds with 32 queries
