Like Tree3Likes
 Old 11-28-2010, 09:22 AM   #441
theo's Avatar
Posts: 53   (View Stats)
theo is a name known to alltheo is a name known to alltheo is a name known to alltheo is a name known to alltheo is a name known to alltheo is a name known to all
Originally Posted by spnkr21 View Post
Do a log using these parameters on the dashhawk: rpm, afr, timing, knock, and boosted air temp
I will do so thanks
theo is offline   Reply With Quote
 Old 11-28-2010, 12:45 PM   #442
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
Also get one with di fuel pressure instead of bat.
2012 WRX HB w/mudflaps yo!
 Old 11-28-2010, 09:41 PM   #443
theo's Avatar
Default Dashhawk log
Hope i got it
 Old 11-29-2010, 03:25 PM   #444
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Log with the SB at the same time you log with the DH and up load them together. It's easier to tune when you can look at everything between the two devices. You'll use the SB log for things like fuel pressure, spark timing, boost and WG parameters. And you'll use the DH log for AFR, KR, BATs etc.
The DH should also always log RPM so you can correlate certain things between the maps. For instance, say you had a lean AFR between 3500 and 4500 rpm. You could then look at the SB log at those rpms, and make sure your fuel pressure okay, etc.
The tuning is fairly straight forward.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
RichieRichness (12-03-2010), wankular (11-29-2010)
 Old 11-29-2010, 03:31 PM   #445
Captain
Groans: 79
Lastly, from looking at your mod list... you'll definitely need an upgraded fuel pump if you don't already have one. And eventually you may run into injector seal issues. Currently there is no replacement for oem, but there are quite a few of us running a beta version of an upgraded seal. And it should only be a matter of weeks hopefully til there is an aftermarket upgrade available.
www.permtuning.com
I Love Brownies (11-29-2010), SilverDemon (11-30-2010)
 Old 11-29-2010, 09:46 PM   #446
theo's Avatar
I did had problems with the seals and replaced them with titanuim so far no problems yet,pushed them to 1.8 bar and they still hold.Stupid ? how do i log on the sb
The Following User Says Thank You to theo For This Useful Post:
djuosnteisn (11-30-2010)
 Old 11-29-2010, 09:55 PM   #447
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
When you say you replaced them with titanuim, what exactly do you mean? You made or had someone make some sort of seal for them? If so do you have any pics of this?
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 11-30-2010, 03:18 AM   #448
theo's Avatar
They had the problem on the race cars,so the machanic made them for me,the guy also did my motor build, I tried to contact him for info on the seals but he is on leave at the moment
 Old 11-30-2010, 06:18 AM   #449
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groans: 31
Groaned at 86 Times in 65 Posts
do you have the big maf housing and all cp-e flashes theo? (throttle, cut, bigmaf)...you would have had to ship cp-e your ecu for those (stock ecu)
-JEWBERT
jhershorin is offline   Reply With Quote
 Old 11-30-2010, 08:26 AM   #450
theo's Avatar
Glad to hear from you.I had the full piasini flash done on the car
 Old 11-30-2010, 08:40 AM   #451
Captain
Groans: 79
Logging is easy with the SB, just need a laptop in the car, connected to the SB. All you have to do is start and stop the logging process in the graph screen, and it automatically logs every parameter. You then use the BBX software to review the log. Both programs and necessary drivers can be downloaded here:
Standback Tuning Software, Drivers, and Logging Software
Glad you got the seal issue taken care of. Sounds like you'll have quite the fun car on your hands once it's finished up
Oh, and i guess using the SB in conjunction with a paisani flash will work just fine. As long as the flash holds the throttle open, and removed any bottle necks in the ecu logic (and believe me, there are quite a few).
I'm not terribly familiar with the paisani, so i won't comment on if it will or won't work properly. Just take it slow, and ease into the power / boost, keeping an eye out for any issues with afr or detonation.
One last thing, not sure if you MAF is stock size or not, but that may become a limitation near 400whp. Keep an eye on your MAF volts (in) in the SB. If your hitting 4.9X it's time to go larger.
Going to a larger maf may be a lil tricky as well, cause ideally you'd need to recalibrate the maf table. Cp-e does this with a flash, and i'm sure the paisani guy's could do it as well. You could also do it with the SB MAF xfer table, but you'll still be limited by the scaled voltage output... though from my experience, you'll be pulling so much fuel off the stock tune, that it might buy you enough headroom.
If you have any more questions, or want me to explain it more, just lemme know.
www.permtuning.com
Last edited by djuosnteisn; 11-30-2010 at 08:40 AM. Reason: MSF Database - Automerged Doublepost
 Old 11-30-2010, 09:00 AM   #452
theo's Avatar
Thanks for the info.Well i have spend so much money on the car because to me it is a toy,it is only used to play with.When i get my wife to go for a spin she say she is going for a face lift because it feels like that.I had a 6.3 AMG but i have more fun with this car than i had with the AMG
 Old 11-30-2010, 09:13 AM   #453
Captain
Groans: 79
If you married a girl who encourages you to mod a car... you done real good sir.
www.permtuning.com
 Old 11-30-2010, 09:31 AM   #454
theo's Avatar
We are married for 26 years now and it is still a h/moon
The Following 2 Users Say Thank You to theo For This Useful Post:
djuosnteisn (11-30-2010), MarkyMark (12-01-2010)
 Old 11-30-2010, 10:57 AM   #455
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
i dunno dude, the AMG is faster then a 400 whp ms3.
i raced one of those with my girl in the car, the AMG was packed out with 4 ppl in the car (big guys) and he still left me.
 Old 11-30-2010, 09:45 PM   #456
theo's Avatar
My AMG was limited on 250km/h,With the unichip you can remove the speed limiter and the ms3 clocked 283km/h on a 1.5 km strip.With the ms3 you feel the speed with the AMG not,nobody expect that speed when you take them on and thats the fun part of it
 Old 12-01-2010, 01:23 AM   #457
SpeedSixxx's Avatar
Groans: 778
so you did 176 mph in your speed 3 and what are your mods?
 Old 12-01-2010, 05:49 AM   #458
theo's Avatar
GT35 Turbo,full 76mm de cat exhaust,turbo man,cai,fmic,d/pipe,Bench flow cyl head,450cc injectors,f/pump,flash,w/meth injection and 100hp nitro.pauter rods,arias pistons,stage 3 clutch.full mountings and at the time used a uni chip.
 Old 12-01-2010, 10:10 AM   #459
Captain
Groans: 79
Pics of port injection please.
www.permtuning.com
wankular (12-01-2010)
 Old 12-01-2010, 10:55 AM   #460
theo's Avatar
I can get you some info from the race cars they are running port injection at the moment,and according to them less problems
djuosnteisn (12-01-2010)
 Old 12-02-2010, 08:26 AM   #461
theo's Avatar
Default SB Data log
I cant get the program to work,i d/loaded it then it is a file BBX then there is a driver ftdi that is zipped do i just extract the file?
 Old 12-02-2010, 08:44 AM   #462
theo's Avatar
do i connect the lap top while driving?
 Old 12-02-2010, 09:23 AM   #463
theo's Avatar
Spoke to the guys that did the port injection on the race cars.The main reason they did it is because they get a constant power band. they use a perfect power stand alone system with 500cc injectors,if you go to a complete stand alone system you will have to change the alt too.But they say that the six mps has a box that drives your injectors not the same as the 3,you should rather get a stand alone just for the injectors and then stay with direct injection.
 Old 12-02-2010, 09:33 AM   #464
Captain
Groans: 79
Correct, the injector driver module on the 6 is a separate unit, and the 3's and cx7's have the module integrated into the ecu.
Theo, did you get your SB and BBX software up and running? You want to extract that FTDI file, and then when you connect the SB to your computer, it'll ask you for the driver. At that time, just navigate to the FTDI file you just extracted and select it.
And yeah, you leave the SB connected to your computer while your driving.
www.permtuning.com
 Old 12-02-2010, 10:33 PM   #465
SpeedSixxx's Avatar
Groans: 778
so I assume that is what the speed 3's final drive is limited to? 176mph?
did you enjoy the world cup this summer btw?:uni tedstates::unitedstate s:
we just lost hard to Qatar...fuckin BS!!
i bet in 12 years qatar will be over run by jihadists...
:uniteds tates:
 Old 12-03-2010, 10:58 AM   #466
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
dj where are you located? I'd assume your pro when it comes to using the SB...i may need some help tuning since im a noob. Jake was helping me a couple months ago but I think he's too busy these days.
 Old 12-03-2010, 01:06 PM   #467
Captain
Groans: 79
I'm in NM... we're all cowboys out here. Send me a pm with your email if you want.
www.permtuning.com
 Old 12-04-2010, 05:51 AM   #468
theo's Avatar
Default SB Data log
Yes i did get it to log but when i tried to open the file the computor does not reconise the file?
I did a adjustment on the boost clip made it 15 and my afr went up to 29 why?
 Old 12-04-2010, 05:56 AM   #469
theo's Avatar
Unhappy
:uniteds tates:
Yes i think to improve that speed you would have to look at the gear ratio that was 7000rpm in 6.
Yes it was nice to have such a big event here,pitty we cant compare to the others the way we do with the rugby.
 Old 12-04-2010, 06:43 AM   #470
jhershorin's Avatar
Groans: 31
Rich- your not to far...lets plan a saturday and we'll just pump it out with a street tune if you want.
-JEWBERT
 Old 12-04-2010, 08:08 AM   #471
theo's Avatar
I am in South Arica it is a bit far.But is it normal if you make the boost clip more that your afr will go up?
 Old 12-04-2010, 08:50 AM   #472
Captain
Groans: 79
Boost clip affecting AFR is not normal at all.
AFR of 29 means the injectors are completely off (fuel cut probably). If this resulted from increasing the Boost clip, then i'd say it's been adjusted too high and your experiencing boost cut.
Do you have the cp-e full control and cut flashes? You should give them a call sometime and inquire about them if not.
Also to open the BBX logs, you need to first open the PMP.exe program, and then import yourlogs (.bbx files) into it. Here, i just made 2 quicky screen shots showing you how:
Now that you have the tools, post up a bbx log and some DH logs so we can get a better idea of what's going on. And perhaps you want to start your own thread if you want.
www.permtuning.com
 Old 12-04-2010, 10:24 AM   #473
theo's Avatar
Thanks DJ WILL GET IT ALL TOGETHER and work from there
 Old 12-04-2010, 10:42 AM   #474
jhershorin's Avatar
Groans: 31
Theo...richierichness lives near me if you want to fly me to south africa i would be more than happy to tune you haha...never been there
-JEWBERT
The Following User Says Thank You to jhershorin For This Useful Post:
djuosnteisn (12-04-2010)
 Old 12-04-2010, 01:47 PM   #475
SpeedSixxx's Avatar
Groans: 778
umm why the fuck is their fuel cut and boost cut flashes not just part of the SB unit?
 Old 12-04-2010, 02:06 PM   #476
Click Here's Avatar
Posts: 202   (View Stats)
Click Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the world
I'm not even sure what you're asking?
Are you asking why the Standback can't flash the fuel cut fix to the ECU?
Or why the flashes aren't provided for free with the purchase of a Standback?
Click Here is offline   Reply With Quote
 Old 12-04-2010, 06:36 PM   #477
Groans: 35
OMG Jake your alive! I'll take you up on that offer dude. I sent you and email a couple days ago...did you get it?
 Old 12-04-2010, 06:48 PM   #478
gerry@ardesign's Avatar
Posts: 136   (View Stats)
gerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond repute
you need to order the cpe big maf instake and full control flashes if you want full capabilities over your turbo. You also need a cpe fuel pump. PM me for pricing.
Need CPE parts at a great price and fast PM me.
gerry@ardesign is offline   Reply With Quote
The Following 2 Users Say Thank You to gerry@ardesign For This Useful Post:
djuosnteisn (12-04-2010), SpeedSixxx (12-06-2010)
 Old 12-05-2010, 10:21 AM   #479
theo's Avatar
Default Standback and D/H Logs
At last i got the logs working(must be the age thats getting to me)First i took the boost clip from 15 to 10 car was much smoother and afr went down to 11.5.here is the logs
djuosnteisn (12-05-2010)
 Old 12-05-2010, 12:11 PM   #480
Captain
Groans: 79
Your AFR's and timing need some TLC. Your timing looks like it's hitting 15 degrees at 5000 rpm, that's way too much man.
www.permtuning.com
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f9/standback-tuning-dummies-guide-official-q-14296/
[Mazda 3 MPS] ECU tunning ? glod wiedzy This thread Refback 08-02-2013 03:24 PM
[Mazda 3 MPS] ECU tunning - glod wiedzy This thread Refback 06-29-2012 04:58 AM
SoCal Standback help This thread Refback 05-16-2011 11:44 PM
standback tuning for dummies - Zuula Search This thread Refback 05-13-2010 12:43 PM
mazdaspeed standback maps - Zuula Search This thread Refback 05-05-2010 08:32 PM
mazdaspeed roush vent install - Zuula Search This thread Refback 03-22-2010 09:19 PM
Day of 1/3/2010: Top 50 of 183 Referring Pages This thread Refback 01-04-2010 10:00 AM
Day of 12/17/2009: Top 50 of 199 Referring Pages This thread Refback 12-18-2009 08:36 AM
Day of 12/2/2009: Top 50 of 217 Referring Pages This thread Refback 12-03-2009 08:20 AM
Day of 10/6/2009: Top 50 of 204 Referring Pages This thread Refback 10-07-2009 08:38 AM
Day of 10/1/2009: Top 50 of 200 Referring Pages This thread Refback 10-02-2009 08:52 AM
Day of 9/13/2009: Top 50 of 181 Referring Pages This thread Refback 09-14-2009 08:57 AM
Day of 7/29/2009: Top 50 of 195 Referring Pages This thread Refback 07-30-2009 08:07 AM
Day of 6/18/2009: Top 50 of 222 Referring Pages This thread Refback 06-19-2009 07:53 AM
Day of 6/16/2009: Top 50 of 223 Referring Pages This thread Refback 06-17-2009 08:20 AM
Day of 6/15/2009: Top 50 of 195 Referring Pages This thread Refback 06-16-2009 07:55 AM
Day of 6/10/2009: Top 50 of 188 Referring Pages This thread Refback 06-11-2009 07:40 AM
Day of 6/4/2009: Top 50 of 193 Referring Pages This thread Refback 06-05-2009 07:49 AM
Day of 5/31/2009: Top 50 of 182 Referring Pages This thread Refback 06-01-2009 08:32 AM
Day of 5/25/2009: Top 50 of 203 Referring Pages This thread Refback 05-26-2009 08:24 AM
Day of 5/21/2009: Top 50 of 213 Referring Pages This thread Refback 05-22-2009 08:29 AM
Day of 4/26/2009: Top 50 of 152 Referring Pages This thread Refback 04-27-2009 07:41 AM
Day of 3/18/2009: Top 50 of 207 Referring Pages This thread Refback 03-19-2009 04:16 PM
Day of 2/26/2009: Top 50 of 199 Referring Pages This thread Refback 02-27-2009 09:10 AM
Day of 2/22/2009: Top 50 of 176 Referring Pages This thread Refback 02-23-2009 08:04 AM
Day of 2/19/2009: Top 50 of 197 Referring Pages This thread Refback 02-20-2009 08:43 AM
Day of 1/28/2009: Top 50 of 276 Referring Pages This thread Refback 01-29-2009 07:41 AM
Day of 12/1/2008: Top 50 of 270 Referring Pages This thread Refback 12-02-2008 08:53 AM
Day of 11/30/2008: Top 50 of 252 Referring Pages This thread Refback 12-01-2008 09:19 AM
So the standback is in. - Carolina Mazdas This thread Refback 11-25-2008 08:56 AM
Day of 11/10/2008: Top 50 of 245 Referring Pages This thread Refback 11-11-2008 08:52 AM
Day of 11/3/2008: Top 50 of 245 Referring Pages This thread Refback 11-04-2008 10:34 AM
Access Tuner Race Tuning Guide Haltech
Cobb ATR Support
6 04-06-2010 12:40 AM
vta tuning on the standback bykeryder4life MazdaSpeed 3/6 - ECU Computer Tuning 14 09-18-2009 08:30 PM
Standback Tuning for Dummies thread?? vbt101 MazdaSpeed 3/6 - ECU Computer Tuning 12 09-02-2009 09:13 AM
FFS and LC in the new tuning guide twisted99
Cobb ATR Support
4 07-23-2009 12:25 AM
Cp-e standback tuning Wisedom MazdaSpeed 6 - How-To's 10 03-31-2009 07:17 PM
Copyright 2008 ; 2019 Cymru Internet Services LLC | FYHN Autosports HQ
Page generated in 0.64045 seconds with 29 queries
