Like Tree3Likes
 Old 04-14-2011, 10:20 PM   #761
Joellc2434's Avatar
Posts: 232   (View Stats)
Joellc2434 is a splendid one to beholdJoellc2434 is a splendid one to beholdJoellc2434 is a splendid one to beholdJoellc2434 is a splendid one to beholdJoellc2434 is a splendid one to beholdJoellc2434 is a splendid one to beholdJoellc2434 is a splendid one to behold
Ya caruch, you are right I didn't know that was how it worked. What do you think that I should have it set at without the flashes 4-5 like you did or does it even matter. Any ways I made a couple of runs. At 16 psi I hit the wall. But at 13 PSI these were my logs. One in 4th gear and the other in 3rd
2007 Mazdaspeed 3 GT: Cobb AP running stage 2+ 91 oct. w/ 3.5 gallons E85, cp-e Xcel CAI, cp-e FMIC, cp-e injector seals, Dashhawk 2 w/ cp-e mount, cp-e side engine mounts, Magnaflow CBE, M2 (ebay) Downpipe, TRZ Dogbone RMM, Denso ITV 22's, SURE Sidewinder TIP, SURE Return, SURE Intake Plenum and Throttle Body TIGs, SURE Shortcut and Countershift, SURE Anchors, KMD HPFP Internals, PNP'd Intake manifold and Throttle Body by Grimmspeed
Working on my Tune
In garage: New exhaust Mani
Joellc2434 is offline   Reply With Quote
 Old 04-14-2011, 10:28 PM   #762
Joellc2434's Avatar
Also Richie I would PM you but I have to get to 15 posts first. I will as soon as I get there. WOuld love some base maps. Thanks again for the offer
Working on my Tune
 Old 04-14-2011, 10:39 PM   #763
MattJackson86's Avatar
Posts: 1,407   (View Stats)
Honestly anything lower than 10 psi is probably fine. Higher and you could hit boost cut. 13psi is probably the upper limit of it working ok, though there is no downside to having it set lower. That way the ECU won't cut boost as it always thinks its so low.
The Following 2 Users Say Thank You to MattJackson86 For This Useful Post:
Joellc2434 (04-14-2011), the_caruch (04-15-2011)
 Old 04-14-2011, 10:51 PM   #764
Joellc2434's Avatar
I'll be trying that tomorrow. THanks
Working on my Tune
 Old 04-15-2011, 07:34 AM   #765
the_caruch's Avatar
Posts: 698   (View Stats)
the_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the world
setting it to 4 or 5 should give you full boost in all gears (not that you'll have traction in first and 2nd). i just wanted to be sure the ecu wasn't limiting boost in any way.
as far as your logs. it looks like it takes forever for the afr's to go down. i was going by your spark advance as to when you hit the throttle. but, with no knock it seems ok.
it would be better to see a standback log of your runs.
here is my lame KR that comes on at almost the same point in every run. I have lowered boost and it lessened the knock a little. 3.5 degrees down to 2.8. I'll play around with a few things to see if i can at least get it to 0. Not sure if it needs more fuel to help cooling. usually my boost is stable, this particular run it oscillated just a bit. FMIC for the win. Temps have never went up during a WOT run. On this run the ambient temp was about 42-45 degrees
cp-e CAI, cp-e Turbo Inlet, cp-e catted DP, cp-e HPFP, cp-e flashes, cp-e Standback w/PNP, cp-e FMIC, TRZ RMM, TS Compact BOV (full re-circ), DDM 55W 6k HID's, Cobb RSB. HKS Hi-Power Exhaust, OCC
the_caruch is offline   Reply With Quote
 Old 04-15-2011, 08:44 AM   #766
I always got knock at that range. Started at 4900ish and then another peak at 5300ish. I never got that 100% under control. Pulled all kinds of timing, played with AFR, and 1 in 3 runs would have it.
 Old 04-15-2011, 09:13 AM   #767
Joellc2434's Avatar
I did pull some timing from areas that I was seeing knock before. BUt I haven't really added much timing in the lower rpms. That should lean me out a little bit down where my afrs are high. Is that right?
WHat should I log with the standback? Spark Timing, RPM, what else?
Working on my Tune
 Old 04-15-2011, 09:18 AM   #768
SB should log everything. You don't have to choose what to log. You do choose what you wanted displayed on the graphs, but everything is logged.
Joellc2434 (04-16-2011), the_caruch (04-15-2011)
 Old 04-15-2011, 09:34 AM   #769
the_caruch's Avatar
Don't use timing to adjust fuel. Just add fuel in the MAF table for those particular rpm's and whatever you are basing the other axis on
You want to be at around 11.5-11.8 generally close to after you go WOT.
Damn. Well i'll report back what i did to eliminate it. I'm going to try a series of things to see what affects it. Not sure if it's the injector seals
Take away my raised fuel pressure -> test
Take away more boost -> test
Add more fuel -> test
Reduce timing -> test
 Old 04-16-2011, 09:54 AM   #770
Joellc2434's Avatar
Im not trying to use timing to adjust fuel. I am just asking if I am right that adding timing will lean out afr a little. WHile pulling (removing) timing will make you run richer.
THis is just something that I have read from being on the forums. Haven't had the experience of testing it much.
Working on my Tune
 Old 04-16-2011, 12:07 PM   #771
Joellc2434's Avatar
Originally Posted by charlesfist View Post
What do your LTFT's look like.
When you first asked this I basically answered from memory but now I have been looking into it more. I was told that my LTFTs should be under 8. When at cruise speed my LTFTs are at 3.9 but if I step into the throttle it goes to 12.5. Is this something that needs to be adjusted. I have been trying to read up on LTFT and STFT but does anyone have a simple explanation and/or some advice.
Working on my Tune
 Old 04-16-2011, 01:15 PM   #772
LTFT is the only one you need to watch. It should be under +/- 8% while in closed loop (not WOT). Closer to 0 the better as this will change with temperature etc, so having it a -8% could go -12% with changes.
In open loop it should be 0%. If it is not, then reset the ECU (unplug battery for 5 mins) and just drive normally for 30 miles or so (no wot). The ECU will relearn the trims. Hopefully then your WOT LTFT will be 0%.
The way to adjust LTFT is via the MAF transfer table. If you have a -5% in a certain maf volts range then in that same maf volts range in the MAF transfer table, start decreasing the numbers (-1, -2, etc) until that range it closer to 0 in your LTFT. Changes to LTFT are not instant, they change over time. The STFT is instant but not a good gauge to what you need to change, so ignore it really.
The Following User Says Thank You to MattJackson86 For This Useful Post:
 Old 04-16-2011, 05:14 PM   #773
Joellc2434's Avatar
Cool. I think that is what I should do is reset my ECU. I don't know if I ever drove very tame for 30 miles after my standback install. Thanks
Working on my Tune
 Old 04-16-2011, 11:41 PM   #774
Np. You may need/want to reset it a few times. Reset, adjust MAF transfer, learn trims, reset, adjust again, etc. You really just want you LTFT perfect before you go any further. If your not in a hurry, give it more than 30 miles. They can definitely take time to adjust, especially in the higher MAF volt range.
Joellc2434 (04-18-2011)
 Old 04-17-2011, 12:50 PM   #775
Joellc2434's Avatar
SHould I be logging MAF so that I know where to adjust on the transfer table? SHould I have everything else on my standback zeroed out again while the ecu is learning trims?
Working on my Tune
 Old 04-17-2011, 12:54 PM   #776
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
You shouldn't have to change the maf xfer. I think 12 for ltft isn't bad. You should check for boost/vac leaks, not change maf xfer.
2012 WRX HB w/mudflaps yo!
 Old 04-17-2011, 06:51 PM   #777
High LTFT is normal if you have mods and not tuned. With my SB removed my LTFT are around 15% or so. I definitely had to modify the maf transfer to get it all in line.
You shouldn't need to log. Just watch the LTFT and take note of when it changes. There are only 4-5 different ranges, so its not like it will change for each different MAF volts. Theranges are around <=1.3v, 1.3v-1.7v, 1.7v-2.1v, 2.1v-2.5v, 2.5v+. They are total estimates but it gives you an idea.
 Old 04-17-2011, 11:35 PM   #778
Joellc2434's Avatar
SO do I lean out ranges that have high LTFTs. Sorry for the ignorance
Never mind found answer in one of your previous posts
Working on my Tune
 Old 04-18-2011, 08:42 AM   #779
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
you need to input positive numbers or add fuel on the maf xfer table if you want to try and correct trims that are too high
the high trim is your ecu's way of saying "there is fuel lacking, so i'm providing more" you need to trick it and make it think there is more voltage then there is from the maf - already more fuel
you can just start the car up with the sb already connected and a read done (with a buddy) - don't try and read with the car on - then you can just input the numbers where you are highlighted as you idle/cruise and watch your trims decrease or increase
just keep in mind when you make a change on the mafxfer that it's for all rpm ranges - so if you add fuel at 1v - it's basically like adding a 1 on the 30x30 table from top to bottom at 1v
also don't forget trims are highly variable depending on weather - so if it's cool now and you do this - when the weather changes all this may need done again..
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following User Says Thank You to cpolly69 For This Useful Post:
 Old 04-18-2011, 01:06 PM   #780
charlesfist's Avatar
Posts: 281   (View Stats)
charlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the world
Looks like everyone has covered everything well, in this response.
I will just say, that since our cars are so MAF based, I like the trims as close to zero as possible.
I do log LTFT's and MAF to see what changes to make at the break points to get it nicely done (This is probably overkill though)
charlesfist is offline   Reply With Quote
The Following User Says Thank You to charlesfist For This Useful Post:
 Old 04-18-2011, 02:43 PM   #781
cpolly69's Avatar
Groans: 27
No it's not - I found (in my experience anyway) that the more you see increased trims in closed loop - The longer it will take to transition into open loop and the higher your load will climb before you transition - If you aren't using the latest atr or don't have the cpe load cut/big maf flash then this will lead to cuts if you go over 200 or so...
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following 2 Users Say Thank You to cpolly69 For This Useful Post:
charlesfist (04-18-2011), Joellc2434 (04-18-2011)
 Old 04-18-2011, 02:56 PM   #782
Joellc2434's Avatar
Well I just said fuck it and ordered up the the fuel cut ad full control flash. BUt now I read the post above about needing the big maf flash. What if I have the original CAI that cp-e released, do I still need that flash?. DO I need to amend my order?
Working on my Tune
 Old 04-18-2011, 02:59 PM   #783
cpolly69's Avatar
Groans: 27
you can't run the big maf flash unless you have the bigger maf housing - it's all a kit you can get from cpe - the car will not run like this on a normal cpe cai
ideally if you are on stock turbo - you would get both the bigger inlet and the bigger maf in order to have the best trims on the big maf/load cap flash
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
Joellc2434 (04-18-2011), the_caruch (04-18-2011)
 Old 04-18-2011, 03:06 PM   #784
Joellc2434's Avatar
Thanks again. I guess that is something that I will worry about later down the road if I ever strive to go for huge power. I guess that I could always send my ECU back again to get that last flash on there. So i guess that I need to get to UPS and send my ECU to Cp-e. Wow thats a lot of 3 letter acronyms for one sentence
Working on my Tune
 Old 04-18-2011, 08:34 PM   #785
the_caruch's Avatar
Be sure to get it insured for about $1000 dollars. If UPS loses it, it's not cheap to get a replacement.
 Old 04-18-2011, 10:52 PM   #786
Joellc2434's Avatar
Ya. On the way to PostNet I called the local dealership to get a price on an ECU and it was $1180 and change so I insured for $1200. Absolutely wasn't going to be caught with my pants down on that one
Working on my Tune
 Old 04-20-2011, 04:35 PM   #787
Matt- THANKS a lot for writing up the new program. Cant wait for the updated one which includes the other OBD parameters, so no more fumbling around with two devices....
Quick status update: I got this working but it has slowed down the logging quite a bit (2-3 samples a second), so I am in the process of getting that back to 6-8 samples a second it was before. Will post when its available on website.
charlesfist (04-21-2011), RichieRichness (04-22-2011)
 Old 04-21-2011, 09:28 AM   #788
That is great news!!!
I, and am sure everyone else here using the SB is really looking forward to this.
Thanks for your continued work on this...
Guessing we would just need a OBD II to usb cable as far as hardware to run this?
MattJackson86 (04-21-2011)
 Old 04-21-2011, 09:33 AM   #789
You will need an elm327 device. I have this one: ELM327 1.5V USB ELM 327 CAN-BUS V1.5a OBD Scanner tool | eBay
But there are tons on ebay that should work. I have only used the USB and serial versions. Not used the bluetooth so no idea how they work exactly.
Ill post when I have it sampling at a fast rate.
 Old 04-21-2011, 11:32 AM   #790
pebenito's Avatar
Posts: 249   (View Stats)
pebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the worldpebenito is the leader of the world
I've got a bluetooth elm327, so when this MST update is available, I'll try. Its probably just a bluetooth->serial bridge, so I would expect it to work as long as its paired with the laptop.
2008.5 MGM Mazdaspeed 3 GT
Cobb AP | cp-e SRI | cp-e TMIC | UR TP | cp-e RMM | JBR SSP | JBR Spherical Shift Knob | JBR RSB | Autotech HPFP | Spin-on
pebenito is offline   Reply With Quote
The Following User Says Thank You to pebenito For This Useful Post:
 Old 04-22-2011, 09:55 AM   #791
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
What is the purpose of using this device?
 Old 04-22-2011, 10:04 AM   #792
Read OBD data from the car via your laptop (i.e Dashhawk).
 Old 04-22-2011, 11:10 AM   #793
Groans: 35
Yeah but what is the advantage of using this over the DH or SB software you've created?
 Old 04-22-2011, 11:11 AM   #794
The ELM327 just plugs into the car where DH does and then other end plugs into laptop. My SB software will read the AFR, BAT, Kr, etc from the ELM327 at the same time it logs SB data and combine the 2 into 1 log file.
 Old 04-22-2011, 11:22 AM   #795
pebenito's Avatar
I also use it to monitor via the Torque app on my phone.
 Old 04-22-2011, 11:44 AM   #796
Groans: 35
Guys...thats pimp! </threadjack>
 Old 04-29-2011, 12:24 PM   #797
Joellc2434's Avatar
So I got my flashed ECU back and I have a question that I think I already know the answer to. Using my dashhawk and putting the pedal all the way to the floor, the dashwak only shows 77% on the TPS. Is this because this is what the flashed ECU is relaying or am I only getting 77% of open throttle? If I logged with the standback would it show full control over the throttle?
Working on my Tune
 Old 04-29-2011, 01:01 PM   #798
spnkr21's Avatar
Groans: 105
Yes
 Old 04-29-2011, 07:13 PM   #799
the_caruch's Avatar
yea, when you look at a SB log the TPS voltage will go to something higher than 4 volts. probably hover around 4.3-4.6v
The Following User Says Thank You to the_caruch For This Useful Post:
Joellc2434 (04-29-2011)
 Old 05-04-2011, 08:42 PM   #800
cbusby's Avatar
Posts: 156   (View Stats)
cbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond repute
Groaned at 10 Times in 1 Post
So I just picked up a used Standback2 and PnP a few days ago, as did a friend of mine and we are gonna give this tuning thing a try together. I realize that everyone is going to the AP, but I liked the price point of the SB and don't plan on going BT anytime soon so I'm hoping this will be okay.
Anyway, I just read every single post here and learned a lot, made a bunch of notes. I gathered from what I read that the first thing I should do is nail down my LTFT's as much as possible. I was pretty surprised when I looked at my Dashhawk and it was reading -14 at idle! A little blip on the throttle brings it to -9. Is it normal to see numbers this negative?
I've made the adjustments to my MafXfer table (0-1.5v: -2, 1.5-2.1v: -1) and will reset the ECU and go for a cruise tomorrow to test. Anybody still monitoring this thread and mind helping me out once I get some logs done?
Also I'm using the modified software by MattJackson and really like it.
Colin
2008 Mazdaspeed3 / Bolted (mostly) / Parting out.
cbusby is offline   Reply With Quote
The Following User Says Thank You to cbusby For This Useful Post:
MattJackson86 (05-05-2011)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f9/standback-tuning-dummies-guide-official-q-14296/
[Mazda 3 MPS] ECU tunning ? glod wiedzy This thread Refback 08-02-2013 03:24 PM
[Mazda 3 MPS] ECU tunning - glod wiedzy This thread Refback 06-29-2012 04:58 AM
SoCal Standback help This thread Refback 05-16-2011 11:44 PM
standback tuning for dummies - Zuula Search This thread Refback 05-13-2010 12:43 PM
mazdaspeed standback maps - Zuula Search This thread Refback 05-05-2010 08:32 PM
mazdaspeed roush vent install - Zuula Search This thread Refback 03-22-2010 09:19 PM
Day of 1/3/2010: Top 50 of 183 Referring Pages This thread Refback 01-04-2010 10:00 AM
Day of 12/17/2009: Top 50 of 199 Referring Pages This thread Refback 12-18-2009 08:36 AM
Day of 12/2/2009: Top 50 of 217 Referring Pages This thread Refback 12-03-2009 08:20 AM
Day of 10/6/2009: Top 50 of 204 Referring Pages This thread Refback 10-07-2009 08:38 AM
Day of 10/1/2009: Top 50 of 200 Referring Pages This thread Refback 10-02-2009 08:52 AM
Day of 9/13/2009: Top 50 of 181 Referring Pages This thread Refback 09-14-2009 08:57 AM
Day of 7/29/2009: Top 50 of 195 Referring Pages This thread Refback 07-30-2009 08:07 AM
Day of 6/18/2009: Top 50 of 222 Referring Pages This thread Refback 06-19-2009 07:53 AM
Day of 6/16/2009: Top 50 of 223 Referring Pages This thread Refback 06-17-2009 08:20 AM
Day of 6/15/2009: Top 50 of 195 Referring Pages This thread Refback 06-16-2009 07:55 AM
Day of 6/10/2009: Top 50 of 188 Referring Pages This thread Refback 06-11-2009 07:40 AM
Day of 6/4/2009: Top 50 of 193 Referring Pages This thread Refback 06-05-2009 07:49 AM
Day of 5/31/2009: Top 50 of 182 Referring Pages This thread Refback 06-01-2009 08:32 AM
Day of 5/25/2009: Top 50 of 203 Referring Pages This thread Refback 05-26-2009 08:24 AM
Day of 5/21/2009: Top 50 of 213 Referring Pages This thread Refback 05-22-2009 08:29 AM
Day of 4/26/2009: Top 50 of 152 Referring Pages This thread Refback 04-27-2009 07:41 AM
Day of 3/18/2009: Top 50 of 207 Referring Pages This thread Refback 03-19-2009 04:16 PM
Day of 2/26/2009: Top 50 of 199 Referring Pages This thread Refback 02-27-2009 09:10 AM
Day of 2/22/2009: Top 50 of 176 Referring Pages This thread Refback 02-23-2009 08:04 AM
Day of 2/19/2009: Top 50 of 197 Referring Pages This thread Refback 02-20-2009 08:43 AM
Day of 1/28/2009: Top 50 of 276 Referring Pages This thread Refback 01-29-2009 07:41 AM
Day of 12/1/2008: Top 50 of 270 Referring Pages This thread Refback 12-02-2008 08:53 AM
Day of 11/30/2008: Top 50 of 252 Referring Pages This thread Refback 12-01-2008 09:19 AM
So the standback is in. - Carolina Mazdas This thread Refback 11-25-2008 08:56 AM
Day of 11/10/2008: Top 50 of 245 Referring Pages This thread Refback 11-11-2008 08:52 AM
Day of 11/3/2008: Top 50 of 245 Referring Pages This thread Refback 11-04-2008 10:34 AM
Access Tuner Race Tuning Guide Haltech
Cobb ATR Support
6 04-06-2010 12:40 AM
vta tuning on the standback bykeryder4life MazdaSpeed 3/6 - ECU Computer Tuning 14 09-18-2009 08:30 PM
Standback Tuning for Dummies thread?? vbt101 MazdaSpeed 3/6 - ECU Computer Tuning 12 09-02-2009 09:13 AM
FFS and LC in the new tuning guide twisted99
Cobb ATR Support
4 07-23-2009 12:25 AM
Cp-e standback tuning Wisedom MazdaSpeed 6 - How-To's 10 03-31-2009 07:17 PM
Copyright 2008 ; 2019 Cymru Internet Services LLC | FYHN Autosports HQ
Page generated in 0.77210 seconds with 29 queries
