Like Tree2Likes
  • 1 Post By ThatJuanMS3
  • 1 Post By Djohns
 Old 11-11-2017, 07:36 PM   #1
ThatJuanMS3's Avatar
Posts: 38   (View Stats)
ThatJuanMS3 has a spectacular aura aboutThatJuanMS3 has a spectacular aura about
Default Trouble codes new engine
So I just got done putting a new engine on the speed. Iím here because I have some trouble codes stopping me from ignition. These are p0123 p0223 p2128 p2088 p0091 and p0098 I believe itís an issue with my wiring maybe a ground. Any insight would help
ThatJuanMS3 is offline   Reply With Quote
 Old 11-11-2017, 09:52 PM   #2
Fstrnyou's Avatar
Posts: 2,148   (View Stats)
Not everyone has those codes memorized. Spell it out for us.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
 Old 11-11-2017, 10:18 PM   #3
Djohns's Avatar
Posts: 3,945   (View Stats)
Groans: 112
There’s a small ground by the fuel pump that would keep you from being able to start. Also did you try installing the engine in the car instead of on it?
2010 black mica speed3
Soon:built motor
 Old 11-11-2017, 10:50 PM   #4
Originally Posted by Djohns View Post
Thereís a small ground by the fuel pump that would keep you from being able to start. Also did you try installing the engine in the car instead of on it?
So I moved I️t to inside the car now so that canít be I️t. Are you talking about the one that goes onto that wiring harness frame thing?
Fstrnyou likes this.
 Old 11-12-2017, 07:22 AM   #5
Djohns's Avatar
Groans: 112
Yes thatís the one. By you saying that I assume you got it. I would go over all your connectors and make sure all of them are tight and right.
danb likes this.
Soon:built motor
 Old 11-12-2017, 09:28 AM   #6
P2128 - Accelerator peda position (APP) sensor No. 2 circuit high input
P2088 - camshaft position actuator A control circuit low (bank 1)
P2101 - throttle actuator circuit range/performance
P0091- fuel pressure regulator 1 control circuit low
P0098- intake air temp sensor 2 circuit high
 Old 11-12-2017, 10:42 AM   #7
Djohns's Avatar
Groans: 112
Sounds like you missed the connector that’s under the intake manifold.
Soon:built motor
 Old 11-12-2017, 11:55 AM   #8
Sounds like you missed the connector thatís under the intake manifold.
The one that goes into the manifold or the big wiring harness one?
 Old 11-12-2017, 11:56 AM   #9
Fstrnyou's Avatar
All of them should be plugged in.
Other rides:
History:
The Following User Says NO Thank You to Fstrnyou For This Un-useful Post:
ThatJuanMS3 (11-12-2017)
 Old 11-12-2017, 09:33 PM   #10
Down to p2128 p2088 p2101 and p0091 ideas?
 Old 12-14-2017, 02:09 PM   #11
sdetweil's Avatar
Posts: 22   (View Stats)
sdetweil is an unknown quantity at this point
did u find your problems?
I just replaced the engine in my sons 2011 speed3 with an engine from a local wrecking yard. (we blew a rod thru the block)..
anyhow I have 5 codes
p0118 - engine coolant high
p0123 - Throttle position high
p0222 - Throttle position
P0335 - Crank position sensor
P2185 - Engine Coolant Temp
i cleared them and P0118, P0123 and P0222 come back.
the replacement engine was very clean, they cut the body side of all connectors, not the engine side. I 'think' I have everything reconnected.. but the TPS errors make me wonder. CPS is worrisome.
and the coolant ones... weird.. I have started to fill rad fluid again, how do you get it to go in? I have maybe 1 gal of 2 loaded.
any guidance would be appreciated
looking more, the Throttle body connector was not seated. now down to P0118.. i rechecked that the ECT sensor is plugged in.. (above generator on back of engine)
sdetweil is offline   Reply With Quote
 Old 12-14-2017, 03:14 PM   #12
Jeff23spl's Avatar
Posts: 1,622   (View Stats)
all the code goes to a common harness...so there must be one not connected or not fully pressed in...just follow the wires from the part and make sure it is fully pressed into each other + in the ecm
You can check individual signals to the pcm to see if it get open (connector) or full voltage(Missing ground) but i bet it would be easier to just double check the work.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 12-14-2017, 03:50 PM   #13
So after a while I just ran through my harness and checked every wire. Sensor cable to the crankshaft position sensor (middle one) was pinched, spliced a new cable in and the speed came right to life
The Following 3 Users Say Thank You to ThatJuanMS3 For This Useful Post:
MSMS3 (12-16-2017), stockms3 (12-14-2017), Thor Hammer (12-14-2017)
 Old 12-15-2017, 03:04 PM   #14
sdetweil's Avatar
thx.. I unplugged the ECT1 sensor (at the radiator), and verified with a wire toner that they were connected all the way thru. I reconnected the sensor and now the P0118 code is gone. so,, the connector was not on completely
still no start... but on to next set of diagnostics
edit: mine turned out to be a broken crank position sensor..
Mazda OBD-II Trouble Codes Haltech MazdaSpeed 3/6 - ECU Computer Tuning 6 07-14-2018 06:35 PM
These are all the trouble codes for mazdaspeed 3 check engine light gt5 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 06-25-2017 03:08 AM
Stocked out my car and now I'm getting trouble codes Brendanb 2010 MS3 - Troubleshoot/Diagnostics 7 09-01-2014 02:15 PM
Trouble codes boostjunky MazdaSpeed 6 - How-To's 5 01-10-2013 07:29 AM
Link to trouble codes...... winniep MazdaSpeed 3/6 - ECU Computer Tuning 2 03-20-2008 07:22 PM
©Copyright 2008 ; 2018 Cymru Internet Services LLC | FYHNô Autosports HQ
Page generated in 0.34912 seconds with 24 queries
