 Old 11-18-2013, 04:23 AM   #1
EmPeEs6's Avatar
Posts: 642   (View Stats)
EmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the world
Groaned at 10 Times in 7 Posts
Default VD - problem with log file
Hi all,
could someone please load the two attached log files into Virtual Dyno and compare the results (the detailed dyno settings and thus absolute power values don’t really matter but should be equal for both files)?
The main difference of the files is that the second one contains more log parameters (and the order of the columns has changed).
I encounter the problem that VD (version 1.2.5) shows completely different results (~310 whp <-> ~265000 whp!?) and I don’t understand why the second log file obviously can’t be read/interpreted properly. Actually the dimension of the two power curves should be the same and the resulting power/torque should also be similar...
Mods: BNR S4, 3" Ray cb, CP-E catted dp, CS 3" intake, CP-E tmic, D06-wmi, itv22/NGK IX plugs, Forge bov, hpfp-upgrade, JBR ebcs, 3 bar map sensor, egr block off kit, ACT 6 pad clutch with SL flywheel, Wiseco oem compression pistons, Manley H-Beam connecting rods, reworked head, CP-E SafeSeal injector seals, no E85, Cosworth thermostat
EmPeEs6 is offline   Reply With Quote
 Old 11-18-2013, 10:16 AM   #2
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
I sorted the columns in alpha order by column title, saved & reloaded in VD. Got the following (my default profile so no doubt the numbers will be off from what you expect)
File Type: jpg Screenshot - 11_18_2013 , 1_13_44 PM.jpg (372.0 KB, 32 views)
340hp / 371tq
EmPeEs6 (11-18-2013)
 Old 11-18-2013, 10:45 AM   #3
Oh, and here are the refined logs-
340hp / 371tq
 Old 11-18-2013, 12:33 PM   #4
EmPeEs6's Avatar
Thank's a lot!
Meanwhile I also managed to get a proper result - after I've tried nearly everything, I noticed that I forgot to specify a tps column in the dyno options (this is required for the latest VD version), then I deleted all not used columns, and after that it worked!?
So, for me it seems that VD cannot handle such many log parameters. In any case very strange...
BTW: run nr. 1 was done without passenger (in contrast to nr. 2) so, as expected, the calculated power values differ by just a few (5) whp.
The Following User Says Thank You to EmPeEs6 For This Useful Post:
TiGraySpeed6 (11-18-2013)
File recovery USMCEvan Computers & Technology News 12 08-19-2011 01:47 PM
Cobb ATR Help File Haltech MazdaSpeed 3/6 - ECU Computer Tuning 0 12-03-2010 03:53 PM
GM plans to file for IPO during week of Aug. 16 Haltech Automotive News 0 07-23-2010 09:10 PM
File upload filter?? SSinstaller Website Help/Feedback 3 04-26-2010 03:01 PM
Invalid File in Signature?? KaiserSoze Website Help/Feedback 3 04-07-2008 07:38 PM
Page generated in 0.24814 seconds with 22 queries
