 Old 11-19-2017, 04:03 PM   #1
BuddySpeed3's Avatar
Posts: 464   (View Stats)
Groaned at 7 Times in 4 Posts
Default VE Tables and upgraded manifolds
Hey guy's, I'm planning to upgrade my intake and exhaust manifolds soon. Have you guys been modifying the VE table at all? I can't find much info on how to modify it, or if it's even truly necessary to tweak it when upgrading to better flowing manifolds.
- 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 2 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress)
 Old 12-02-2017, 01:08 PM   #2
Ofcourse the volumetric efficiency of the engine will increase with higher flowing manifolds and from what I've read the VE table should be tweaked when upgrading the manifolds. I'm just trying to see if anyone has any experience tuning with these installed. Like is there anything to look out for such as running lean, boost spikes, etc? I read that if there are certain rpm/load regions where there is a lean spike, increasing the value in that region in the VE tables is a good place to start. Thanks for any info!
 Old 12-02-2017, 07:44 PM   #3
Fstrnyou's Avatar
Posts: 2,231   (View Stats)
Solely my opinion, but if your MAFCAL is spot on, you should be able to tune the VE tables using the same method as a MAFCAL. Albeit a lot more complex/time consuming.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
 Old 12-03-2017, 08:22 PM   #4
So do you mean using the multiplier obtained from Actual AFR / Target AFR, and multiplying it by the values in the VE Table at a given load/rpm region?
This seems like a good idea
I figure I'll start by enriching my maf curve slightly for safety when testing the new manifolds.
Then I'll do a maf cal with OL fuel trims disabled.
If there are any abnormal variances in actual AFR, I'll do what I can to the maf curve to meet targets.
If it gets to a point where corrections cause the maf curve to become un-smooth, and still not meet AFR targets, then I suppose I could multiply the values in the VE Table in that specific load/rpm region with the same maf cal multiplier and see if it increases or decreases fueling.
Ideally I'd like to only need to make changes to the maf curve and not have to touch the VE tables at all, but it's pretty much pure experimentation at this point lol, and I stored the car for winter, so I gotta wait until spring.
 Old 12-03-2017, 09:35 PM   #5
Fstrnyou's Avatar
I'm not entirely sure if messing with the VE table is even necessary. The MAF tells the ECU how much fuel to put in. Whether 50% VE or 100% VE, X amount of air gets Y amount of fuel. If you've increased the flow of the intake or exhaust manifold and/or the head with porting, the MAF will see that increase and input the appropriate amount of fuel.
With a MAF, are VE tables even necessary? Perhaps the VE tables are an emergency backup for when the MAF fails? Like a limp mode lookup table.
I really hope someone who knows will chime in before we get too far out of whack.
Other rides:
History:
The Following 2 Users Say Thank You to Fstrnyou For This Useful Post:
BuddySpeed3 (12-05-2017), DingoDave (12-05-2017)
 Old 12-03-2017, 11:02 PM   #6
mituc's Avatar
Posts: 3,511   (View Stats)
Groans: 111
The volumetric efficiency has to do with the way the air enters the engine and not with the MAF calibration.
So changing any of the manifolds does not require any VE tables changes, however changing the cams does.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 12-04-2017, 04:16 AM   #7
Fstrnyou's Avatar
Googled and skimmed a few tuning threads. It seems my original thought is more correct. If your MAFCAL is good, use fuel trims to adjust VE.
Other rides:
History:
BuddySpeed3 (12-04-2017), DingoDave (12-05-2017)
 Old 12-04-2017, 04:33 AM   #8
Awesome, I'll give it a try if a maf cal doesn't work. Thanks!
 Old 12-05-2017, 05:40 AM   #9
mituc's Avatar
Groans: 111
According to this logic, deleting the VCTS requires the same approach, because at least in the low coolant temp/low load/low rpm the speed of the air entering the ports differs.
But again, because the volumetric efficiency refers to the amount of air that makes its way into the cylinders messing with the VE tables is not required.
The Following 2 Users Say Thank You to mituc For This Useful Post:
 Old 12-05-2017, 07:28 AM   #10
Fstrnyou's Avatar
The MAF is always "on" and, if it's calibrated properly, no amount of mods at the engine should affect the way it measures the air. Changes to the airflow pattern immediately before, after, and/or at the MAF sensor would be the only reason to do a new MAFCAL.
With a good MAFCAL, any mod that changes your fuel trims means the VE table needs to be messaged a little.
Other rides:
History:
 Old 12-05-2017, 08:20 AM   #11
Ok so this is going to take some testing once the manifolds get installed It makes sense that the maf sensor determines how much fuel is required. But, if there are lean spots during a pull that are difficult to cure with corrections to the maf curve, I have a feeling making adjustments to the VE table values in that load/rpm region will help. This is just speculation though.
 Old 12-05-2017, 04:09 PM   #12
mituc's Avatar
Groans: 111
Post a log. And yes, this is just a speculation and those lean spots are caused by something else.
 Old 12-06-2017, 04:13 PM   #13
Ok thanks man! I'll post some logs come spring time when I put the car back on the road.
Any risk when setting throttle req load tables high to force boost by gear tables? 08Anamoly
Cobb ATR Support
5 03-29-2010 07:52 PM
intake manifolds... bombdotcom MazdaSpeed 3/6 - Turbo Induction 31 01-30-2009 11:26 AM
Intake manifolds?? steedspeed MazdaSpeed 3/6 - Turbo Induction 74 10-25-2008 07:00 AM
manifolds?!?! Grim Mazdaspeed3/6 General Discussion 136 09-13-2008 10:47 AM
Page generated in 0.33137 seconds with 22 queries
