![]() | | #1 | ![]() |
![]() Join Date: Jan 2012
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score Are there any good tuning guides for Versatuner? |
![]() Join Date: Nov 2010 Location: Manchester, England
Rep Power: 707 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,201
Groans: 34
Search on the versatune website for a thread called "map editing" it's long, but every question is answered in there. It was my first attempt at tuning and I just kept badgering steve with questions.
__________________ Tuned with by ![]() Su tmic/corksport intake/custom 3" tbe/grimmspeed ebcs/forge bpv/jbr ssp/jbr rsb/Jbr side mount/sure tig set/sure r3 rmm/kmd internals/pg sst (tune in progress)/3 gauge pod |
When reading abilor tuning guide it all refers to the AP, would be nice if there was a VT tutorial as well. | |
![]() | | #4 | ![]() |
Rep Power: 6724 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,349
Alot of the table names are close enough to figure out. It took me a bit to get comfortable with the names, now I dont even notice.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant |
![]() | | #5 | ![]() |
Where are these in Versatuner Closed Loop exit Delay A? Closed Loop Max Load D? Fuel OL commanded EQ base? Fuel commanded EQ max enrichment allowed? WG duty Cycles? |
![]() | | #6 | ![]() |
![]() Join Date: Sep 2011 Location: Stockholm Sweden
Rep Power: 96 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 245
Groaned at 14 Times in 7 Posts
I've always tried to understand what is what but noone seems to know much about VT. Ive tried this and my local forum.
__________________ Mazdaspeed6 -06 Versatuner @ Base 93/98 High Load DP Map w/ Tactrix Corksport: SRI+TIP - Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit JBR: RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2 Simons 3" Catback CP-E: TMIC - Diff Mount - Catted Downpipe Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel 3 bar MAP Sensor with PNP Harness Not installed yet: JBR TIG IM, Techna-Fit Clutch Line, NGK IX @ 0.0275, Boost Dial, Techna-Fit Brake Lines, ProSport Oil Filter Adapter + Spin-On Conversion, Block8Head Dual Gauge Pod Last edited by SpeedRebirth; 08-31-2012 at 04:31 AM. |
![]() | | #7 | ![]() |
| Scammer Hunter ![]() ![]() Join Date: Mar 2008 Location: Jacksonville, FL
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
Groans: 449
| Not Ranked : 0 score Steve@VersaTune is a vendor here.
__________________ ![]() ![]() ![]() 1) Looking to Buy a used Mazdaspeed? Read this! 2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here. 3) Wanna buy and sell here? DONATE for VIP 4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting! 5) Help MSF grow with FAQ threads!? |
![]() | | #8 | ![]() |
| Engineered Tuning ![]() ![]() ![]() Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 8362 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,244
Have tuned many VT cars and the tables are all there. The table descriptions are also good at the top of the screen so if you're comfortable with tuning overall it won't be an issue.
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() | | #9 | ![]() |
Thanks for your reply Lex. Wish someone created a guide for Abilor Tuning with the VT names in would help alot. AP ---Fuel OL commanded EQ base? as a value of "14.60" across Load 0.25 and RPM 500 - 5000 VT --- Open Loop Part Throttle AFR Target Normal - - has a value of "1" across Load 0.25 and RPM 500 - 5000 |
![]() | | #10 | ![]() |
Groans: 34
14.68 = 1 lambda
__________________ Tuned with by ![]() Su tmic/corksport intake/custom 3" tbe/grimmspeed ebcs/forge bpv/jbr ssp/jbr rsb/Jbr side mount/sure tig set/sure r3 rmm/kmd internals/pg sst (tune in progress)/3 gauge pod | |
![]() | | #11 | ![]() |
![]() Join Date: Dec 2011 Location: Massachusetts
Rep Power: 41 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
Is the versa tuner just as good as the cobb? Is one better than the other?
__________________ |
![]() | | #12 | ![]() |
![]() Join Date: May 2011 Location: Sykesville, MD
Rep Power: 788 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 519
Groaned at 49 Times in 20 Posts
You should on be using Versa Tuner if you live where the AP isnt available.
__________________ 2008.5 BM MS3 // Cobb AP // JBR 3.5" WP Full Intake // CXRacing Piping/Godspeed Core // CNT 3" Catted Downpipe // Custom 3" CBE // KMD v2.1 Fuel Pump Internals // Turbosmart Dual Port BOV // Raceland Coilovers // JBR 88Duro Dogbone RMM // JBR SSP // SURE AGS Knob // Denso ITV22 // Aeroforce Interceptor Scan Gauge // STACK Boost Gauge // DDM 6k Low HID's // CP-e Towplate // CP-e Defrost Vent Pod // 15% Tint // 17x9.5 Work Equip Anhelos FREEK PERM ![]() |
![]() | | #13 | ![]() |
Can't you ship an ap anywhere in the world? Sent from my DROID4 using Tapatalk 2
![]() | | #14 | ![]() |
| Not Ranked : 0 score Yes you can, but its ECU specific. Example, a US ECU is different than a UK ECU.
![]() | | #15 | ![]() |
Makes sense Sent from my DROID4 using Tapatalk 2
![]() | | #16 | ![]() |
Groans: 34
| Not Ranked : 0 score They're pretty much the same.
![]() | | #17 | ![]() |
The biggest difference is that the ap comes with a handheld device whereas vt must have the laptop plugged in to log. Furthermore gen2 support is only on the cobb so far.
![]() | | #18 | ![]() |
Thanks for the info, would be nice if there was a VT guide tho |
| Hello from VersaTune | Steve@VersaTune | VersaTune | 62 | 03-09-2012 10:53 AM |
| VersaTune - CL to OL transition table | joey | MazdaSpeed 3/6 - ECU Computer Tuning | 3 | 11-18-2011 01:44 AM |
