 Old 06-18-2012, 08:19 PM   #1
Blackrider's Avatar
Posts: 356   (View Stats)
Blackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the world
Groaned at 20 Times in 14 Posts
Default WG Problems.
A few weeks ago I was trying to dial in my WGDC and boost targets and I noticed that in the higher RPM's no matter how high I set my WGDC it would taper right down to nothing. I thought it might be an issue with the EBCS so I pulled the trigger on a Grimmspeed 3 port which I was going to get anyways. So last night I had some spare time so I installed the 3 port and tried and dial in my WGDC and boost targets but I had the same damn thing happened. I can hit my target boost all the way up to 4500 RPM but then it starts to taper no matter how much WGDC I'm commanding furthermore, the logged WGDC shows a steady decline all the way down to zero.
I'm targeting 20 Lbs from 3000-5000 RPM, 19 Lbs from 5000-5500, 18 Lbs from 5500-6000 and 17 Lbs from 6000-6500.
I've tried running as much as 90% WGDC from 5000-6500 but the logged WGDC still tapers all the way down to zero. I tried flashing a stage 2 OTS map and I had the same problem.
Am I missing something simple here or do I have a real problem?
Log attached, mods as per signature.
2008 MazdaSpeed 3
Exhaust - Mazdaspeed & Ebay Downpipe
Induction - MazdaSpeed CAI, Unknown TIP, JBR TIG's & CXR FMIC
Tuning - Auto Tech Internals, Cobb Accessport, Grimmspeed 3 port EBCS
Suspention - Koni FSD's, RX-8 Rims, Potenza RE - 11's 235 / 40 / 18's
Drivetrain - J-Speed Shifter Plate, Sure Anchors, SU RMM
Random - Pontiac G8 Horns
2013 Ford Edge Sport AWD, the family car...
Blackrider is offline   Reply With Quote
 Old 06-19-2012, 02:58 AM   #2
Boost_creep's Avatar
Posts: 829   (View Stats)
Boost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the world
Sounds like a mechanical issue.
David goes into a bit more detail in this thread:
Tales of the ECU
www.dizzytuning.com
www.facebook.com/dizzytuning
Boost_creep is offline   Reply With Quote
The Following User Says Thank You to Boost_creep For This Useful Post:
Blackrider (06-19-2012)
 Old 06-19-2012, 06:17 AM   #3
Blackrider's Avatar
Tales of the ECU
Thanks for the link, so if I've ruled out the EBCS and vac/boost lines, I guess I'll have to have a look at the WG.
2008 MazdaSpeed 3
VVT Problems MazdaCX7Failure CX-7 > Issues & Troubleshooting 14 03-20-2013 02:34 PM
VVT Problems mrmonk7663 CX-7 > Engine, Transmission & Driveline 6 04-01-2011 06:47 AM
Few problems need help MS6 KoleDeRacer MazdaSpeed 6 - Engine, Transmission & Driveline 8 01-03-2010 09:26 PM
problems:( MS6Gfeh MazdaSpeed 6 - Engine, Transmission & Driveline 2 09-27-2009 02:12 PM
will these fit my car with no problems?? 18psiWhiteMS3 MazdaSpeed 3/6 - Wheels & Tires 5 06-11-2009 04:09 PM
Page generated in 0.24482 seconds with 22 queries
