 Old 11-11-2009, 11:01 AM   #1
Wenis Prinkle's Avatar
Posts: 176   (View Stats)
Wenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud ofWenis Prinkle has much to be proud of
Groaned at 143 Times in 33 Posts
Default who's played with there ignition table / timing ??
Was wondering what would happen if i advanced the timing a degree or so for WOT. My car runs great now, got my boost, fuel curve, ect.. dialed in off the stage2SF93Oct map and now i think i wanna try messing with the timing just a little bit. has any one done this??
I attached my last data log of me running WOT 2nd to the end of 4th gear for you to see if the conditions are ok to add a degree of timing. that knock u see was just because i forgot to shut off traction control oops. Lemme know what u think. thanks.
Wenis Prinkle is offline   Reply With Quote
 Old 11-11-2009, 11:11 AM   #2
speed23's Avatar
Posts: 1,480   (View Stats)
I agree that traction control was working cause your throttle closed from ~75% to ~50%. However, I believe that your knock comes from your VERY low fuel pressures.
 Old 11-11-2009, 12:20 PM   #3
i noticed that too, and it only happens when my traction light is flashing during wheel spin, ive always assumed the ecu does that. it never happens any other time.
 Old 11-25-2009, 08:10 AM   #4
martin_nj's Avatar
Posts: 581   (View Stats)
martin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the worldmartin_nj is the leader of the world
Groaned at 9 Times in 5 Posts
we know the ecu pulls fuel when the TC light comes on but we don't know how. maybe it takes away some voltage from the pump? that would sort of explain the lower FP
2009 Mazdaspeed3 SOLD!
Summit Point Main 1:32.725 (on all seasons)
Lime Rock Park 1:05.419 (R888)
Pittsburgh Int. 1:09.594 (R888)
NJMP Lightning 1:21.203 (R888)
2013 Ford Mustang GT
NJMP Lightning - 1:25.04 (stock car with 235/18 pirelli all seasons)
NJMP Lightning - 1:20.087 (modded car with 245 summers)
Pocono North - 1:06.xx (Dunlop SP600 245x18) wet
Pocono North - 1:00.655 (275mm Conti Slicks)
Lime Rock - 1:07.2 (Dunlop SP600 245x18)
1989 Honda CRX Si
VIR Full Course - slowww
Summit Point Main 1:35.230
Renault Spec Racer
Lime Rock Park 1:04
VIR Full Course 2:30
martin_nj is offline   Reply With Quote
 Old 11-26-2009, 04:38 PM   #5
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
I have played with advancing the ignition timing a few percent from the .31 to .63 range between 2500-3500 RPM to see if I could get better gas mileage for cruising on the highway, but I didn't see anything measurable, so I returned it to where it was.
 Old 11-26-2009, 04:40 PM   #6
you cant adjust timing fully with ATR because theres another map that only protuners can see which is total timing advance or something. thats the table that really needs to be edited.
Broxer (03-25-2011)
Ignition tables Trader
Cobb ATR Support
7 08-22-2009 11:40 AM
Star Lambo dealer played fast, loose with funds Haltech Automotive News 0 04-19-2009 10:10 PM
HKS Ignition Amplifier Laloosh MazdaSpeed 3/6 - ECU Computer Tuning 25 09-29-2008 05:31 PM
Ignition Amplifier - Information Please TurboWagon MazdaSpeed 3/6 - ECU Computer Tuning 13 04-30-2008 09:49 AM
Page generated in 0.27220 seconds with 25 queries
