 Old 05-27-2011, 12:35 PM   #1
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
Default WTF IS UP WITH MY DATA LOGS
Ok, I just did the latest firmware update for my accessport, went and saw there were not new versions of the OTS maps. So I decided to add FFS to the OTS v108 stage 1 sf + FMIC, and then flashed it. I went to do some datalogs to do a MAF cal and this is what I got. I don't even know what to say.
 Old 05-27-2011, 12:52 PM   #2
sick BAT's haha, i can haz your fuel pump?
Fatguy729 (05-27-2011)
 Old 05-27-2011, 01:01 PM   #3
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Is there a way to roll back your firmware?
 Old 05-27-2011, 01:14 PM   #4
Fatguy729's Avatar
Groans: 82
I think my AP is fucked up... Everything looks normal when I am monitoring except the boost. Its reading fucked up and flashes for some reason like the shift light is going off. I tried to call Cobb, but no one answered and I left a message. I am worried what may have happened when I flashed the map and if my car is running right. Everything seems normal, but I don't know.
This was me in 2nd gear....
 Old 05-27-2011, 01:35 PM   #5
Shayne @ COBB's Avatar
Posts: 12   (View Stats)
Shayne @ COBB has a brilliant futureShayne @ COBB has a brilliant futureShayne @ COBB has a brilliant futureShayne @ COBB has a brilliant futureShayne @ COBB has a brilliant futureShayne @ COBB has a brilliant futureShayne @ COBB has a brilliant futureShayne @ COBB has a brilliant futureShayne @ COBB has a brilliant futureShayne @ COBB has a brilliant futureShayne @ COBB has a brilliant future
Fatguy,
I apologize for us not answering the phone when you gave us a call. I know that can definitely be frustrating.
I believe what has happened is that between your old firmware and the latest, we changed the way the AccessPORT reads boost from the ECU. Because of this change, everything needs to be updated (map on the car, firmware, etc.) in order for the boost reading to come through properly. Once everything is brought up to current versions, the boost reading should be fine again.
Please note that this means that your vehicle is very likely running just fine - the issue is with how the AccessPORT is reading boost from your ECU.
Now, I realize that you mentioned using the latest OTS map (v108) and are on the latest firmware, but since you modified the map with AccessTUNER, it may not be behaving as the latest version.
I would recommend reflashing the vehicle to an unmodified v108 OTS map then checking to see if your Boost reading functions properly. If it does, the issue is with your current version of ATR. If not, we'll have to explore other possibilities (I'm not sure what else would cause this, so...).
If you'd like, you can feel free to email me at shayne@cobbtuning.com and I will be happy to help you out with any of this directly. (You can email me your phone number and I'll give you a call, if you'd like to handle it by phone, also.)
Shayne @ COBB is offline   Reply With Quote
The Following 7 Users Say Thank You to Shayne @ COBB For This Useful Post:
clowncar (05-27-2011), darkcambria (05-27-2011), Fatguy729 (05-27-2011), neotide87 (05-27-2011), rfinkle2 (05-27-2011), superskaterxes (05-27-2011), wolly6973 (05-27-2011)
 Old 05-27-2011, 01:46 PM   #6
Fatguy729's Avatar
Groans: 82
I figured maybe an early holiday weekend LOL... So what's up with my datalogs?
 Old 05-27-2011, 02:06 PM   #7
Fatguy729's Avatar
Groans: 82
Ok, I flashed back to an unmodified map and its fine. So how do I update ATR?
 Old 05-27-2011, 02:11 PM   #8
Fatguy,
Send me an email with your ATR information (name, email, serial number, model/make/year) and I'll see about having the latest version of AccessTUNER sent to you.
The Following 2 Users Say Thank You to Shayne @ COBB For This Useful Post:
Fatguy729 (05-27-2011), rfinkle2 (05-27-2011)
 Old 05-27-2011, 02:11 PM   #9
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
Open it up.
Help -> Updates -> Check for Updates
 Old 05-27-2011, 02:17 PM   #10
Fatguy729's Avatar
Groans: 82
Originally Posted by wolly6973 View Post
Open it up.
maybe that is an option for gen 2, but not gen 1
Originally Posted by Shayne @ COBB View Post
Fatguy,
will do... thank you for the fast response/help!
 Old 05-27-2011, 02:18 PM   #11
Wolly's suggestion may work, depending on what version of ATR you have. The automatic updates feature was not always an option, unfortunately.
Feel free to try that first. =)
The Following User Says Thank You to Shayne @ COBB For This Useful Post:
 Old 05-27-2011, 02:19 PM   #12
Fatguy729's Avatar
Groans: 82
LOL I edited my last post, not an option on my version
 Old 05-27-2011, 02:21 PM   #13
clowncar's Avatar
Posts: 994   (View Stats)
clowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the world
Groaned at 23 Times in 15 Posts
I LOVE COBB
Their customer service is freakin tits
I drive an old RX-7 because I like breaking down a lot.
clowncar is offline   Reply With Quote
The Following 3 Users Say Thank You to clowncar For This Useful Post:
Fatguy729 (05-27-2011), rfinkle2 (05-27-2011), superskaterxes (05-27-2011)
 Old 05-27-2011, 02:36 PM   #14
Fatguy729's Avatar
Groans: 82
Email sent
 Old 05-27-2011, 02:46 PM   #15
Holy cow. I just checked my spam email and saw that you've sent me a few, Fatguy. I apologize for not getting back to you on those.
I'll get on that copy of ATR for you now.
Stupid spam filter!
Three Data Logs ATAZ MazdaSpeed 3/6 - ECU Computer Tuning 1 01-02-2010 02:46 PM
how do my data logs look ? jracer MazdaSpeed 3/6 - ECU Computer Tuning 10 01-01-2010 04:38 PM
Alot more data logs ms3guy22 MazdaSpeed 3/6 - ECU Computer Tuning 15 03-13-2009 05:58 PM
buildabongs data logs Buildabong MazdaSpeed 3 - Engine, Transmission & Driveline 32 10-13-2008 01:18 AM
data logs WTF !! knock ? TRU-BOOST MazdaSpeed 3/6 - ECU Computer Tuning 11 03-10-2008 02:09 PM
Page generated in 0.39140 seconds with 26 queries
